Electric Brakes - INOP
   / Electric Brakes - INOP #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
While rewiring my trailer I applied 12VDC to test each brake, this one did nothing. How do they work and where can I get parts? TIA
   / Electric Brakes - INOP #2
#1 is your electric magnet that when activated gets attracted to the inside surface of your 'moving' drum. This pulls the magnet to the right or left, can't tell in this pic.
#2 is the arm that the magnet is attached to and gets push to the right/left by the magnet.
#3 is a 'cam' that rotates from the arm movement and spreads the top portion of the brake shoes apart.
Chances are your magnet can be replace by itself.
   / Electric Brakes - INOP #4
For some types of axles you can get bolt on replacement brake units. These are almost as inexpensive as doing the replacement piecemeal.:D
Try Goggling Dexter axles and check out some sites.:D
I have purchased the Dexter brake replacement components at an RV dealer.:D
Wow! - Great Video.
After this explanation I'm going to clean all the rust from my brakes components and see if it works. If not I will replace the magnet. Thanks very much for the quick replies.
   / Electric Brakes - INOP #7
And by the looks of your shoes, going with a complete assembly vs just a new mag as the others have stated would be my path also.
I've used Etrailer many times before with 100% satisfaction.
   / Electric Brakes - INOP #8
Me being the electronic geek that I am wouldn't use those Scotch locks as shown in the video. I have had too many of them corrode over the years and not make good connections. I soldered my wires together to the brake wires. Just my two cents worth of wisdom.
2008 Ford F-450 Crew Cab Service Truck (A55973)
2008 Ford F-450...
16 T/A TRASH TRAILER (A55745)
16 T/A TRASH...
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
1999 WABASH 48X102 FLATBED TRAILER (A55745)
1999 WABASH 48X102...
2020 ISUZU NQR (A55745)
2020 ISUZU NQR...
1995 Generac 94A04738-S 125 KW Towable T/A Diesel Generator (A55851)
1995 Generac...
