electric chute rotation for a PTO snowthrower???
   / electric chute rotation for a PTO snowthrower??? #11
</font><font color="blue" class="small">( I search the site and never found that window motor thread )</font>
I think you were looking for this thread in which Von used such a motor.
   / electric chute rotation for a PTO snowthrower??? #12
That setup looks great to me. The only thing I might add is some kind of a cover. Perhaps a cut up plastic piece from a snow saucer mounted on standoff or threaded rod to keep the snow off of the assembly.
Andy )</font>
we were going to add a cover, but i figured if it got bound up or iced up it would be easier to deal with without the cover.
   / electric chute rotation for a PTO snowthrower??? #13
</font><font color="blue" class="small">( I'm curious was that cable and jack-shaft used to originally rotate the chute? Ours uses a similar setup, see picture. )</font>
we made the jack-shaft and mounting bracket, but yes it was originally set up that way . i really wanted to use a chain to spin the chute, but couldn't find a sprocket that could be cut and attached to the chute.
   / electric chute rotation for a PTO snowthrower??? #14
One simple way would be to remove the electric spout turning assemble from a old New Holland field chopper. Some versions used a cable, some used a chain and some used a sprocket and worm gear.
   / electric chute rotation for a PTO snowthrower??? #15
</font><font color="blue" class="small">( I search the site and never found that window motor thread)</font>
Maybe your second suggestion of the same thread may work, Bird. /forums/images/graemlins/blush.gif
   / electric chute rotation for a PTO snowthrower??? #16
</font><font color="blue" class="small">( Maybe your second suggestion of the same thread may work )</font>
Dang, Chris, I need to read more carefully; don't know how I missed your post. /forums/images/graemlins/blush.gif
   / electric chute rotation for a PTO snowthrower??? #17
Comment not directed towards you, Bird; intended for the original poster - he should pay attention and read his own thread. /forums/images/graemlins/smile.gif
ah, hey Doc, not being nasty, but you must not being reading this thread too closely yourself. My comment was referring to an eatlier post on my thread that did indeed point out the use of a wiper motor. I was merely commenting that I missed that thread in previous search attempts before I posted. I always try to find threads that address my questions before I post one. And I DEFINITELY READ MY OWN THREADS CLOSELY!
   / electric chute rotation for a PTO snowthrower??? #19
</font><font color="blue" class="small">( Comment not directed towards you, Bird )</font>
If it wasn't, it should have been. /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
2153 (A58376)
2153 (A58376)
2012 MACK GU713 (A58214)
2012 MACK GU713...
HASIMAN CYCLE ELLIPTICAL (A58374)
HASIMAN CYCLE...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
JOHNSON OUTBOARD MOTOR (A58374)
JOHNSON OUTBOARD...
2004 MACK CH613 WATER TRUCK (INOPERABLE) (A58214)
2004 MACK CH613...
