Electric rad fan s650-g
   / Electric rad fan s650-g #1
Garrettp
S650-g
Has anyone ever done an electric rad fan on s650g? Tired of replacing plastic parts from the 70s... What operation temps should I have this fan run at.?
   / Electric rad fan s650-g #2
Just make sure your alternator can handle the load ;)
I would set the turn on temperature a bit over the thermostat temperature, then full speed 10-20°s above that.
Do you know what the amperage output is of the alternator on satoh s650g? I want to say around 35 amps but could be wrong. I just know at this point I'm low on options, I just had a fan break apart and take out my new rad, so had a recore done for 880$.....
   / Electric rad fan s650-g #4
I put a mini one-wire alt in mine, and I think it was around 35A too.
If you check the voltage at the battery while the fan is running, it should stay around 13.5-14.5v. Ideally the voltage would stay the same with the fan on and off. Then you know the alternator is providing enough for it.
Ouch......:oops:
All I can say is this fan has fatigue cracks all over... And I couldn't see them until it ripped apart...
This was the ultimate cause though I think... My tractor / blower has no pins so it just killed the tractor.....
   / Electric rad fan s650-g #7
alt on mine is 35 a. --- the new fans are low draw so you wont have any trouble runnin it if you dont have any other stuff hooked up. lights/etc.
John Deere 7130 (A53314)
John Deere 7130...
2005 Sterling Acterra Tender Truck (A57024)
2005 Sterling...
2016 Chevrolet Traverse SUV (A55853)
2016 Chevrolet...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
FORREST RIVER CHEROKEE CAMPER (A52472)
FORREST RIVER...
2016 Freightliner M2 106 Braun Ambulance (A53422)
2016 Freightliner...
