Electrical connector at back (of Large frame series)
   / Electrical connector at back (of Large frame series) #11
The one I am working on looks more like a rear tail light plug in a car. I am trying to figure out what pin is what. Thanks for the reply, I wish it was that one as you can buy adapters for it I believe.
   / Electrical connector at back (of Large frame series) #12
I just scrolled thru the elecrical breakdowns for my 8050,
thought I might see the short wiring harness that would connect to your 10 pin and go back to
the trailer connector, no luck on that, did find the trailer connector, (European style)
TZB9440000A3 TRAILERSOCKET,
Correction I went back and saw that I had a PDF breakdown for a 4720 and scrolling thru I found an
electrical page which had a part number for item #44;
TZB9440000A3 TRAILER SOCKET ***'Y, looking at the picture that appears to be the complete
assembly to plug into your 10 pin connector it does also include the Euro trailer connector
Lou
   / Electrical connector at back (of Large frame series) #13
To continue, after I posted the previous post I did a search for the part number posted;
it found a tractorbynet post from 2004 and 2010 with that part number and it suggested that it would cross to this
Pollak #11-933p.
Pollak 11-933P 7-Way RV Harness Adapter
and this is the Branson part;
WASHER LIQUID TANK
It says liquid tank but it comes up with the electrical connector
Lou
Reg: Did you ever find a connector for this plug?
Hi,
No it is yet another thing that I never followed up on to the very end.
Howeverrrrrr, it looks like LouNY has the answer.
Congrats to Lou, I think you have it (-:
At something over $30 by the time shipping and taxes are added it is something I may have done in the first few years if it had been found then, but it hasn't been a PRESSING NEED these last dozen years, so I'll pass.
   / Electrical connector at back (of Large frame series) #15
I tested the pins on the female connector under the seat and they do perform the trailer light functions. One wire is also hot with the key switch on for chargeing the battery or a work light I believe. I might just cut the receptacle off and splice the wires to a north american 7 pin trailer receptacle.
Thanks for the replies.
Mine is 2012, 4020R
   / Electrical connector at back (of Large frame series) #16
Or just go plug and play;
with the Pollak 11-933, and 11-893,
unless you wanted to get fancy and use Hopkins 40975 receptacle.
Yanmar YT359 (A53317)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
