electrical/ pressure switch question
   / electrical/ pressure switch question
The pressure switch should stay as close to tank as possible, the switch if relocated to box would be subject to to much pressure fluctuation as when the pump was charging system and when it shuts off afterwards.
I can,t believe an electrician wired it this way after you explaining what you wanted to accomplish. As kayssupply stated, it's not code but wire ahead of switch to your desired location or figure out how many H2O outlets you need open to keep pump running.
Since you have not run any wire to your desired location, just means a bit of digging from uninterrupted power source.
I'm still not quite understanding what you mean.
   / electrical/ pressure switch question #22
Like the red line in drawing, my 2 cents says to keep pressure switch at current location and connect your 110v outlet to sub panel, if your not familar with electrical connections or have never done before, I would suggest you have one that does complete the connections.
   / electrical/ pressure switch question #23
or figure out how many H2O outlets you need open to keep pump running. Just my lame attempt to make light of situation, (pun intended)
   / electrical/ pressure switch question #24
At a shop where I worked the lifts were 220v and wired so that one leg was always hot unless power was turned off at the fuse box... yes... it was old and each box had two Edison 20amp fuses.
On the top of the life was a trouble light that always worked and was plugged into the hot side.
The lift pump was started and stopped only be making and breaking the connection on one legged.
I have no idea if this would be satisfactory for your situation.
   / electrical/ pressure switch question #25
Some people use one side of a 240 outlet and grab a wire off of the ground to make a 120 light or outlet work...but this is not a real 120 volt system. Your using the ground to complete the circuit and thus really eliminating the grounding source on this circuit.
if a proper 220 circuit was run you would fine two (2) hot wires, one (1) white neutral and one (1) ground wire run.
As an electrician by trade, i cannot condone branching off a 120 outlet off of a 220 circuit UNLESS a neutral wire is actually run, Believe me ive seen some hokey setups out there. Things like taking the bare copper ground wire an making it a neutral and installing a new ground rod at the sub panel. What that leaves you with is an UNGROUNDED 220 volt, 40 amp circuit that is a death trap.
You mean running a totally seperate wire from the house panel to the pond. That would be close to 1,000ft and cost quite a bit in wire. That is why I put the breaker box in because it is halfway to the pond.
It proably won't meet code, but I don't think any of this project will, how about wiring the leg you want hot ahead of the switch and switch the other side of the 220? That way your leg will stay hot but the pump won't come on until the switch makes at the house.
Wouldn't that make a constant 110v to the pump? And then make it 220v once the pressure switch calls closes? I don't think a constant 110v at the pump would be good..
I wonder if switching to a 110v pump would afford a few more wiring options?
   / electrical/ pressure switch question #28
I have run into alot of 240 motors where they turn it off and on by switching only 1 leg of the circuit. It works, but is frowned upon. Theres also a safety issue involved...mainly someone thinking the circuit is off cause the motor isnt running, but its actually 1/2 hot. Personally i never place a switch on a motor unless i break all hot legs.
and your right, there would always be some power running down to the pump...and you are paying for any power you use.
Would switching to a 110v pump give me any other wiring options to make this work?
   / electrical/ pressure switch question #30
I have terrible well water , full of iron. but, I also have a creek that originates on my property so, I put a 220v submersible pump into the creek, then all the required filters on it and now i have wonderful water.
I obviously ran 220v wire ( 8/2 I believe it was) 500ft to my creek for the pump. I also have a very nice large pond that we use for hanging out and swimming in the summer. I would like to have electric down by the pond. So, I put a breaker box in halfway down my field to split off the 220v for the pump. I had an electrician wire it up so now I have a 220v breaker and a 120v breaker in the breaker box. I have yet to run the 120v wire to the pond.
But then I realized that the only time I will get power to my 120v outlet by the pond will be when the pressure switch is closed and calliing for water to my house.
how can I solve this problem without running ery expensive wire 500ft again? Maybe put the pressure switch after the filed breaker box somehow????/
Have you verified with tester at above mentioned box that in fact current cycles with pump or is this an assumption, just trying to pinpoint.
Brock 48'x16' Flat Bottom Grain Storage Tank (A57148)
Brock 48'x16' Flat...
2007 Yamaha Rhino 660 (A56438)
2007 Yamaha Rhino...
Freighliner Tender Truck (A56438)
Freighliner Tender...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
