Elongated Holes
   / Elongated Holes #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So a few weeks ago I posted about how my steering cylinders where flopping around... I wanted to show you the elongated holes. This is something that my 1850 suffers from in a variety of places. I don't think that this is the best design, but I get why they do it. I will order new ears, or makes some up next time, but for the moment I welded on grade 8 washers and replaced the bolt and that will keep me through the summer.
   / Elongated Holes #2
that shouldn't happen if there is enough lubrication.. it probably ran dry.. the short bearing surface contributed to that too, is that 1/2" that wore?.
   / Elongated Holes #3
It looks to me somebody already welded a washer on top of an elongated hole and that matches the grove cut into the bolt. Just a note, be careful welding on the hyd reservoir when full of oil.
   / Elongated Holes #4
So it appears.
Not enough contact/bearing surface. Needs to be a sleeve or tube.
Grooves in the bolt confirm that.
Drilling oversize and using a matching oversized bolt/pin would be a preferred fix.
   / Elongated Holes #5
Yikes!
It seems like somebody, you?, has already done that quickie fix, but you are putting a great deal,of the hydraulic force on a small area, with the washer taking the brunt of the force. You can see all the wear on the bolt.
New eyes are the way to go. Welding them on should be a quick fix, depending on your tools for cutting metal.
Drilling an eccentric hole like that is tough on the drill and bit, but it can be done. However, it isn't going to leave you with much metal, and I would worry about the strength of the eye if you go over size.
All the best,
Peter
   / Elongated Holes #6
So it appears.
Or drill oversized then put in a bushing to reduce the hole down to the size of the original bolt.
Aaron Z
   / Elongated Holes #7
I have used shaft couplings to make bushings. Sometimes had to add gussets each side to reinforce where cutting out for the OD of the bushing doesn't leave much meat. Tack a flat plate on the back side of the elongated hole and use a hole saw to cut out for the bushing.
Ron
   / Elongated Holes
I am more wondering why the original elongated. I seem to be the only one in the group with this issue.
   / Elongated Holes #9
ANYONE ELSE WITH WEAR LIKE THIS???? Is it in all joints in the machine or just one? How many hours? Did you do the proper 8hr lube? What task was the machine used for?
I lube my machine religiously but even so, after sitting for a few weeks when I started using it on a job, it had a creek. Not knowing if it could be that center pivot (Z bar) on the loader, I spoke to Terry. He said the ball joints need more lube. Now I spray them up after every hard workout, it is easy enough. Far quicker cleaner easier cheaper faster, did I mention easier then using a grease gun!!!!
   / Elongated Holes #10
Souunds similar to my 425. I thought for sure the steering valve was going out with the horrible noises I'd hear when turning. Terry said lube the steering ram ends. I told him I did. He said do it again, but really soak them down. OK sure buddy. So I soaked the heck out of them and guess what? The sound went away. :ashamed: Even though I was lubing them often, apparently I wasn't putting enough lube on them. So now I spray them all down as I walk around the machine, then make a second pass. That seems to give it time to soak in.
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58216)
PALLET OF 15 4X8...
Giyi 59" Compactor Wheel (A57149)
Giyi 59" Compactor...
2012 Bobcat 90" Finish Mower (A57148)
2012 Bobcat 90"...
CHECO HYDRAULIC GREASE INJECTION UNIT (A58216)
CHECO HYDRAULIC...
2021 WANCO, INC LIGHT PLANT (A58216)
2021 WANCO, INC...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
