Emergency exit from storm shelter (dedsign problem)
   / Emergency exit from storm shelter (dedsign problem) #1
Gitche Gumee Kid
NW WI
IH 284
A question that is a follow up to my emergency storm shelter exit,(5/12 /13).
I have 50' of 60"" corrugated pipe for the project on order. It weighs in at 55#/ ft. I'll get three sections. Ideally I will get 17 ' sections.
Question. What's the best technique to safely handle large diameter pipe?Can an attachment be fabricated to more safely handle the pipe? I have a
IH (model 374 )tractor/fel and a mini excavator ( Takeuchi TB016 ) both have a lifting capacity of approx 1000#s . Would wide nylon slings be best?
TIA
GGK
   / Emergency exit from storm shelter (dedsign problem) #2
I have lift longer sections of culvert but a lot smaller and lighter then you are looking at. I used a 16' length of 4x4 hung off the excavator bucket. With the beam hanging level it was quick and easy to grab a section of pipe move it to and lower it in the ditch. Both ends of the 4x4 had short lengths of chain with hooks that I used to grab the ends of the culvert.
The photo is one I grabbed off the net.
   / Emergency exit from storm shelter (dedsign problem) #3
We throw a strap around the middle of it and adjust it to hang level .
   / Emergency exit from storm shelter (dedsign problem) #4
I had a lot of pipe to install so the beam was quicker once leveled. For three sections depending on how much room you have either way would work.
Pallet Of Assorted Shackles (A57454)
Pallet Of Assorted...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 LOAD TRAIL 35+5 GOOSENECK TRAILER (A58214)
2019 LOAD TRAIL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2016 FREIGHTLINER...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
