Engaging PTO at other than idle
   / Engaging PTO at other than idle #11
Great discussion about how to engage the PTO on your CUT. Now my question is...How should you disengage the PTO? at high idle or should you reduce engine speed first?
My Allis Chalmers 620 tractor manual recommends that you engage the electric clutch at low speed (just as this discussion is recommending), but it recommends disengaging the PTO at high speed. Makes sense as the attachment will then coast to a stop putting no reverse forces on the PTO clutch. However, my Kubota tractors have hydraulically engaging PTO clutches that make sense with the low speed engaging, but at what speed should they be disengaged? At high speed, but what about the PTO braking mechanism? Will the attachment momentum of a bush hog or similar high momentum attachment quickly wear it out? Disengage at low speed and allow the PTO clutch pack to absorb the momentum? The manuals don't say.
Your thoughts!
OrangeGuy
   / Engaging PTO at other than idle #12
I think an attatchment should be disengaged at low rpm, for a couple of reasons: 1) there is no hp being applied to anything, just momentum, so there will be less strain on everything than when under load, and 2) if you disengage at high rpm, you have NO control of your attatchment at all. If someone/something somehow got caught up in it, you'd have no way to slow it down any faster than it would do on it's own. If something got caught up in it at slowdown speed, at least you could kill the engine with the PTO engaged and stall the attatchment quicker.
Just a thought. /forums/images/graemlins/smile.gif
   / Engaging PTO at other than idle #13
I idel mine down, engage PTO bring engine up to PTO speed and start working, do the reverse when shutting off the pto. ithing the book on the tractor or mabey the RFM said to do it that way. BESIDES just seems like the right way to do it.
   / Engaging PTO at other than idle #14
I engage mine at or below 2000 RPM (as stated, the manual says half throttle). I disengage at or below 2000.
John
   / Engaging PTO at other than idle #15
JWE,
Er??? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif I'm pretty sure the Max RPM of the BX is WELL below 4000. I think you'd be better off engaging/disengaging at or below 1500rpm. It's your rig, but I suspect it will serve you well for a lot longer if you do.
Anyway my 2cents on the whole issue is I engage mine at low RPM's and then trottle up to the needed speed for the use. I also try to throttle down before disengaging, especially with the rotary cutter, to slow the impliment down before disengaging. It brings the mower to a stop faster and will preserve the PTO brake.
   / Engaging PTO at other than idle #16
Larry, you are right about the max RPM on the BX. It is around 3200 RPM. It idles at 1200 RPM so half throttle is about 2200 RPMs.
John
   / Engaging PTO at other than idle #17
When someone does this with their lawn tractor ( engage at WOT) I like to compare it this way: If you have a vehicle and everytime you take off, you rev the engine up as high as you can and dump the clutch, whats going to happen? 1- your going to wear your tires out ( same as drive belts) 2 your eventually going to tear up your drive train ie.. clutch, u-joints,gears,due to the immense shock load your placing them under.
As the others have said I engage and disengage at idle or nearly idle. Diesels make lots of torque and they're made to take a load at low rpm.
   / Engaging PTO at other than idle #18
To start I also idle down, engage, and then up the RPM's to desired speed.
When finished, I idle down, and disengage the PTO slowly. I think it protects the brake on my PTO that way. Better than slamming it into the disengage position and a lot easier on the equipment I think.
   / Engaging PTO at other than idle #19
It makes sense to me that engaging at a low RPM would be easier on the PTO clutch. However, I wonder why Kubota instructs to engage the PTO at half throttle.
John
   / Engaging PTO at other than idle #20
would a bx22 stall if you engaged a 3 pt chipper at low idle.
2019 Generac Mobile MLT4200 20KW Towable Light Tower (A52377)
2019 Generac...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
