Detroit 60
Can anyone give me the contact details of Bruce Livingston in New Zealand regarding the Gravely to Honda adaptor plates. Thanks Andrew
Did you every fine him??
Bruce Guthrie
Try shebru@paradise.net.nz for Bruce LivingstonHi all
I have GRAVELY LS need help
I wanna ask you, becouse I made repowering too, change the original Gravely engine for new Honda GX200. At original GRAVELY with original engine, there was transmission lubricated from engine. How can I lubricated transmission when I use new Honda GX200? Can you help me please?
Thanks you very much!
Martin
Hi all
Martin
Hi all
Martin
Yes if you locate the "special" stuff (GL4) that works, wont eat the brass gear. Last I know from those into Gravelys said engine oil for the trans also.
Just use 50 or 60wt motor oil. It's as thick or thicker than 90wt gear oil, is readily avaliable and is yellow metal friendly.
I believe that would work also. There were many viscosities recommended over the years and quite honestly as long as the oil is "yellow metal friendly" the quantity in the axle is more important than anything,,, nothing tears out planetaries (expensive) quicker than the lack of lubrication! Thicker oils may pose problems in very cold climates, the old L model transaxles were pressure lubed along with the engine and the change to Kohler engines left the transaxle with splash lube also.
