engine oil filter for tc40
   / engine oil filter for tc40 #11
Unfortuneately, you will not find a cross reference anywhere indicating such.
   / engine oil filter for tc40 #12
If the Ford number was FL1A the FL300 is the short version.
   / engine oil filter for tc40 #13
don't know if it makes a difference but fl1a is a ford filter and fl300 is a chrysler filter, both from gas engines........
   / engine oil filter for tc40 #14
They both fit a number of Chryslers and Fords.
   / engine oil filter for tc40 #15
Yes, and Kubotos and New Holland and Ford Tractors, etc. See somewhat incomplete listing attached.
   / engine oil filter for tc40 #16
I have also cross referenced the filter for my NH TC48DA to a Kubota filter. I though it was due to the metric threads for the spin on.
   / engine oil filter for tc40 #17
</font><font color="blue" class="small">( I though it was due to the metric threads for the spin on. )</font>
I don't think so in this case. /forums/images/graemlins/blush.gif The threads are 3/4" - 16 tpi.
   / engine oil filter for tc40 #18
FL1 or FL-300 Motorcraft filter; Will it work on a TC-29? 3 cyd. If it does; this thread may save CNH owners big money and increase ease of changing oil due to convienence.
   / engine oil filter for tc40 #19
Pretty sure. I believe the block on the 29 is the same as that on my 1720 and my dad is still using the FL300 filiter on that. The FL1A is pretty big and probably overkill, but I know it's probably THE most available filter, and I see no reason it wouldn't work. The seal position and threads are identical between the FL1A, 300, and 400 Motorcraft filters.
   / engine oil filter for tc40 #20
My NH Dealer sells a WIX filter 51521 that he cross referenced for me to replace my 87415600 that my TC48DA requires. Its the larger size not the puny little thing NH has gone to. Cost me $4.00 as opposed to the $9.50 for the 87415600 and my thought is that the larger filter would work better. Jim
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2015 Dodge Charger Sedan (A51694)
2015 Dodge Charger...
2015 Hooper T/A Trailer w/Mounted Foaming System (A53117)
2015 Hooper T/A...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
2025 Mower King SSRC (A50123)
2025 Mower King...
2016 Crane Carrier Co. Low Entry T/A New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
