radioman
Super Member
hmm .. did you check the oil dipstick to make sure its up to level?
I think you can use either access. I use the one on top of the valve cover with a long tube funnel because it is the easiest to get at. (have a BX2660)
on most small kubota engines there is a oil filler cap on both sides of engine ,its there because these engines are installed in all kinds of machines, I know my bx25 had two oil filler caps, a picture would help
TBN is great. I had no idea my BX2660 has two OIL ports; when I last changed the oil I just put new oil into the only port I found. Now I know there are two of them.
Thanks.
