Engine oil testing????
Status
Not open for further replies.
   / Engine oil testing???? #21
KICK said:
my opinion is that as long as you are easily impressed and make the assumption that everybody else is as easily impressed as yourself then I can accept it as proof.
unfortunately I'm not all that impressed.
Facts impress me.;) Not fiction . If Having facts to back something up is what you would call "easily impressed''. Then, I'm easly imperssed. Impress me with more facts. Got any plain o'l dino facts to imperss me with :confused:
   / Engine oil testing???? #22
anthonyk said:
Well, each time I took the sample, it was about 2 ounces, so I added 2 new
ounces back. I check the level periodically and have never found it to be low. I guess I've probably added a quart of oil in 2 ounce increments over the past 3 years. That's not much:)
anthony
Uh, didn't you add back a qt at every filter change, too?
Or was there only like 1/2 qt in the pan at that 95k mark.... ;)
jb
   / Engine oil testing???? #23
Kick- At least he posted something here.
If that is not impressive by your standards, please by all means show me some dino oil in a everyday car/truck, same FF filter etc with that duration. Please do not show the Detroit diel trucks etc since that is not even in the same league.
To me, anyway your cut it that is great just show that UOA test #'s.
   / Engine oil testing???? #24
How ya doing frank ? Haven't seen ya around much.Hope you & yours had a merry christmas. Happy new year to ya
   / Engine oil testing???? #25
Hi Kenmac- Doing okay. I try to come out here what I can. Hope you also had a good holiday and a great ?New Years!
Still love the oil threads...:D :D :D
   / Engine oil testing???? #26
You know, this was not intended to be about impressing people.
I passed that information on because it helped save me thousands of dollars and many hours of work. I hope others can enjoy the same savings. I'm not an amsoil dealer, in fact I'm just a professional musician (with an engineering degree)
I'd also like to point out that you're right about seeing what the future brings, but since there are literally hundreds of thousands of vehicles, many of them with even higher mileage than mine, going strong, I guess I'll just take my couple grand and mosey on down the road with a smile:)
best of luck,
anthony
   / Engine oil testing???? #27
Oh, just saw the last posts.
I only need an ounce or two for the analysis, so that's all I had to replace every ten thousand miles. What would that be? 9 tests at say, 2 ounces max? When I removed the filters, I always tried to minimize the loss, but I'd guess you could raise the estimate of the oil replaced. I never really measured, just checked the dipstick, but it was never very much. For the sake of the arguments, Let's say double it. So I guess I've add maybe 2 quarts of oil over the course of the usage. Not because it was worn out or burned, but because I'd removed it for testing.
I'd still have to say, that's mighty impressive. I guess we'd have to reduce my estimated savings by ten or 15 bucks, but I'm still smiling.
anthony
   / Engine oil testing???? #28
actually, the methodology Anthony K employed is fine, but kenmac sounds like he's EZ. I'm not, been exposed to too many tests over time to believe in anything but the long term result, and if it takes years so be it... I never said I don't use Synthetic Oils, I don't know where that assumption comes from, but you know what they say when people ASSUME things.
In my experience any of those ISB series is going to run 95,000 miles... I've got about 200 of em at wirk, on a 6000 mile OCI, which amounts to about every 300-500 hours of running time between oil changes, using cheapest oil the fleet can buy and cheapest filters we can get on low bid, and they all have a service life that goes past 300,000 miles. at the moment we are buying some cheap oil called Imperial...was Fram for awhile, might be Powerguard right now on the filters, doesn't matter, whatever is low bid.
so no Iaint impressed... if anthony goes 600,000 miles on that engine on 6 oil changes, I'll be impressed.
Wait and see is my attitude.
I' ll give you a list of some of my credentials since i cant post a UOA for something I've never done.
To become ASE certified, you must pass an ASE test and have at least two years of full time, hands on work experience. If a passed test is current under test history and not listed under certifications, please update your work experience.
Your Certifications
Certifications lists all tests you have passed with work experience on file.
Type Expiration Date
A1 Engine Repair EXPIRED 07/01/1992
A4 Suspension and Steering 12/31/2009
A5 Brakes 12/31/2009
A6 Electrical/Electronic Systems 12/31/2009
A7 Heating and Air Conditioning EXPIRED 01/01/2005
A8 Engine Performance EXPIRED 07/01/1992
H2 Diesel Engines 06/30/2012
H4 Brakes 12/31/2011
H6 Electrical/Electronic Systems 12/31/2011
H7 Heating, Ventilation, & A/C 06/30/2012
L2 Electronic Diesel Engine Diagnosis Specialist 12/31/2012
S1 Body Systems and Special Equipment 12/31/2008
S2 Diesel Engines 12/31/2008
S3 Drive Train 12/31/2008
S4 Brakes 06/30/2008
S5 Suspension and Steering 12/31/2008
S6 Electrical/Electronic Systems 06/30/2008
S7 Air Conditioning Systems and Controls 06/30/2008
T1 Gasoline Engines 06/30/2010
T2 Diesel Engines 06/30/2010
T3 Drive Train 06/30/2010
T4 Brakes 06/30/2010
T5 Suspension and Steering 06/30/2010
T6 Electrical/Electronic Systems 06/30/2010
T7 Heating, Ventilation and A/C 06/30/2010
T8 Preventive Maintenance Inspection 06/30/2010
Your Current Registrations
Current registration indicates tests signed up for in the upcoming test period.
Type Test Date Test Center
Your Test History
Test history shows which tests you have registered for in the past. History for tests taken before 1990 is condensed.
Type Test Date Status
A1 Engine Repair 05/12/1987 Pass
A4 Suspension and Steering 11/09/2004 Pass
A5 Brakes 11/09/2004 Pass
A6 Electrical/Electronic Systems 11/16/2004 Pass
A7 Heating and Air Conditioning 11/03/1993 Pass
A7R Recert A7 - Heating and Air Conditioning 11/11/1999 Pass
A8 Engine Performance 05/12/1987 Pass
H2 Diesel Engines 05/08/2007 Pass
H4 Brakes 11/14/2006 Pass
H6 Electrical/Electronic Systems 11/14/2006 Pass
H7 Heating, Ventilation, & A/C 05/08/2007 Pass
L2 Electronic Diesel Engine Diagnosis Specialist 11/15/2007 Pass
S1 Body Systems and Special Equipment 11/18/2003 Pass
S2 Diesel Engines 11/20/2003 Pass
S3 Drive Train 11/20/2003 Pass
S4 Brakes 05/06/2003 Pass
S5 Suspension and Steering 11/18/2003 Pass
S6 Electrical/Electronic Systems 05/06/2003 Pass
S7 Air Conditioning Systems and Controls 05/08/2003 Pass
T1R Recert T1 - Gasoline Engines 05/17/1986 Pass
T1R Recert T1 - Gasoline Engines 05/13/2003 No Show
T1R Recert T1 - Gasoline Engines 11/18/2003 Pass
T1R Recert T1 - Gasoline Engines 05/05/2005 Pass
T2R Recert T2 - Diesel Engines 05/14/1996 Pass
T2R Recert T2 - Diesel Engines 11/09/1999 Pass
T2R Recert T2 - Diesel Engines 05/05/2005 Pass
T3R Recert T3 - Drive Train 05/14/1996 Pass
T3R Recert T3 - Drive Train 11/09/1999 Pass
T3R Recert T3 - Drive Train 05/05/2005 Pass
T4R Recert T4 - Brakes 05/14/1996 Pass
T4R Recert T4 - Brakes 11/09/1999 Pass
T4R Recert T4 - Brakes 05/05/2005 Pass
T5R Recert T5 - Suspension and Steering 05/14/1996 Pass
T5R Recert T5 - Suspension and Steering 11/09/1999 Pass
T5R Recert T5 - Suspension and Steering 05/05/2005 Pass
T6R Recert T6 - Electrical/Electronic Systems 05/14/1996 Pass
T6R Recert T6 - Electrical/Electronic Systems 11/09/1999 Pass
T6R Recert T6 - Electrical/Electronic Systems 05/05/2005 Pass
T7 Heating, Ventilation and A/C 05/08/2003 Pass
T7R Recert T7 - Heating, Ventilation and A/C 05/05/2005 Pass
T8 Preventive Maintenance Inspection 05/08/2003 Pass
T8R Recert T8 - Preventive Maintenance Inspection 05/05/2005 Pass
   / Engine oil testing???? #29
I'm gonna go for a million on this one!
heh heh...
Seriously, because I'm a fairly gentle driver, I really am curious as to how far this one will go. I have a feeling the truck will fall apart before the engine does!
Keep you posted,
anthony
   / Engine oil testing???? #30
Your Certifications
Your Test History
Good try kick but,
I don't see where you are certified in any engine oil, oil analysis(using different oils) ,performed any oil test yourself through oil analysis, engine wear, etc, etc,. So, I'am not empressed:eek: . Guess I'am not that EZ;)
I'll list some of my certifications. Mine have nothing to do with oil but, neither does yours:p
NATE certified- 2006
H.V.A.C certified -1988
Master plumber- certified-1990
Master gas fitter- certified-1990
Natural gas fire fighitng-certified-1988
Pipe line inspections -certified- 1985
Plastic pipe fusion- certified- 1991
Status
kids dirt bike (A53424)
kids dirt bike...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
25077 (A51694)
25077 (A51694)
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
Pair of New 700/40-225 Alliance Tires with Rims (A55301)
Pair of New...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A52377)
2012 Vermeer...
