Engine Overhaul Kama 554
   / Engine Overhaul Kama 554
Thanks again guys ...
I don't know about "there was never any doubt", because truthfully, I was sweating bullets over this whole ordeal and I prayed it would come out good. Never having done this, it wasn't exactly encouraging to me.
I was soooo close to saying "screw it, I'm selling it".
But I got to thinking about all the stuff I've done with that tractor ... all the improvements and modifications I've done to it over the years. I just couldn't get rid of it. Most of the stuff I broke (other than this) was due to operator malfunction. Which I could've broken on any other brand tractor ... regardless. Crashing into a boulder and snapping off a tie rod end for example, or churning the gears forward and backwards at high speed with 2,500lbs in the bucket in 4wd stressed and eventually broke my front drive gears. All those things would have screwed up any other tractor too (IMHO), because most warn against doing so right in the owners manual.
The little annoyances of owning a Chinese tractor like things not being machined exactly right are easy to fix (but annoying nevertheless). The electrical problems, which I know nothing about are a pain too. But now, one phone call and "POOF" Larry is here to fix it in 9 minutes. So I can live with it. I figure I've saved pretty close to $100,000 (no kidding because I got quotes for several projects) in dirt work, backhoe work, road work, plowing, mowing etc. Quite an outstanding return for a tractor that I paid $10,800 bucks for. Throw in the Koyker loader with 72" bucket, an 8' Nardi Backhoe, a Howse 6' Rotary Cutter, my famous 7' Howse Boxblade and Leinbach Post hole digger, the package went all the way up to $18,500 for all of it. I had to pay $2,000 for shipping to my property, so if you count that, the total was just over 20 grand delivered to my doorstep (campsite back then). Not bad for all that I saved. How many guys can say that their tractor has paid for itself almost 5 times over in 4-1/2 years? Yeah, I've spent money on modifications, regular maintenance and repairs over 5 years, but a lot of that is normal. I do all my own maintenance and repairs (and even mods) so my expenses are way less than having to take it to the dealer for service or repairs (or mods). It just goes to show you that owning a Chinese tractor may not be for everyone. If you don't (or can't) do the work yourself, it may end up not being such a good deal after all. In my case I view it as a great deal.
I've been through just about every part on that tractor by now.
Just about everything is either OK as is, or has been modified or improved to American standards. I've always posted both the success stories and failures equally, so you guys know the good, the bad and the ugly about this tractor.:) Even though I didn't end up balancing the pistons and rods, I did make a chart of all the measurements, fits and tolerances. I also have a book for all the Napa replacement parts. This is of most value since I know I can get parts for it. This project took me to another level of tractor ownership. It's given me more confidence...that I can overcome even some of the greater problems. Certainly a lot more satisfaction.
It's been pouring here as I see it is over much of our state and others.
Even so, I think, later, I'll take Huge Kama out and hook up the FEL and maybe the backhoe. I am still in a semi-unconscious state of shock that it runs so well and smooth, with a lot of oil pressure. And at the same time, I feel exhausted, if you know what I mean.
I was also gonna go pig hunting earlier today because I saw rooting ALL OVER Murder Meadow right in front of South Camp where Brian visited me the first time and Larry and Ken stayed when they visited. But I couldn't wait to check out the forum first.
Rob-
   / Engine Overhaul Kama 554 #252
Gosh Rob, you forgot to mention the priceless degrees you earned. Mechanical, Electrical, and Metallurgical. Those go well alongside that real world MBA. :D
   / Engine Overhaul Kama 554 #255
WOW ! I gotta say- this thread has left me speechless! :eek: I doubt it if I have the guts to do what you did. I would've just dropped in a new motor and be done with it, but then before long I would've had same issues as before. So I gotta say- I give you more then a super A+++ for guts, A+++ for doing a job well done. I am sure its the best feeling in the world to get your tractor up and running now before then before. :D Congrats.
Maybe you can help me with my kubota if run into the same issue in the future ..:eek: Should be easier with a tiny motor compared to yours.:p
   / Engine Overhaul Kama 554 #256
Rob - Thank-you for another fantastic read.
You and that Kama should be inseparable after this venture. It should make you proud to know your baby inside and out. How could you ever part with her now? :)
Now go out there and make us proud with a new project around the ranch.
   / Engine Overhaul Kama 554 #257
I wore my best flannel for that picture. :D
...and it may never be the same again.
I get the onerous task of trying to get all that oil and grease out! After 'Spray & Wash'ing it, pre-soak with in-wash stain remover, using the stain cycle, and OxiPlus, the stains are out, but it still smells like oil and grease. :(
and he wasn't kidding about it being his best flannel shirt.
   / Engine Overhaul Kama 554 #258
Loretta
try soaking it in powered dish washer soap in some water for a couple of days
tom
   / Engine Overhaul Kama 554 #259
Looks like Rob has a new "shop" shirt now!:D I've got several. I wear them over my other shirts. Welding is pretty hard on them but cooler than my leathers.
   / Engine Overhaul Kama 554 #260
Congrats Rob and Loretta!
I totally agree with evertone else's positive comments and of course I am selfishly thankful (AGAIN) for the outstanding documentation on how to fix our tractors. I think your posts have added at least $1000 to the practical value of my Kama.
Loretta - some Goo-Gone or one of the other citrus type degreasers might help with that smell.
I also agree with Jay - sometimes I like to crap up a newer shirt (sorry Diane) just so I'm not wearing old rags in the shop :)
Brad
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A52377)
2021 Ver-Mac...
48 Inch Grapple Root Bucket (A55218)
48 Inch Grapple...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A55218)
2015 RAM 5500...
