Engine Rebuild
   / Engine Rebuild #12
ATTABOY!!! Eddy, as soon as you said 1/4" ring gap I knew you had it nailed.
   / Engine Rebuild
Really taking my time, that's all you can do at my age, it took about 4 hours. That's installing new seat too. These are really easy engines to work on.
I had the head at a machine shop for valve grinding and new valve seals, I got it back about 12:30 and I was mowing by 6:00. You have to figure a nap in there too.
   / Engine Rebuild #14
congratulations! Should be good for another 25-30 years.
Mark
   / Engine Rebuild #15
</font><font color="blue" class="small">( congratulations! Should be good for another 25-30 years. )</font>
Eddie or the tractor?
   / Engine Rebuild
I guarantee the tractor will definitely out last me!!!!
I finished mowing with it this morning. It has more power and I love looking at the gauges and seeing it on 160-180 degrees even pulling hard!!!!!! /forums/images/graemlins/tongue.gif
   / Engine Rebuild #17
(Eddie or the tractor?)
Hopefully both!
Eddie,
Did you just do the upper end? Was there any taper in the bore? Curious about the crank, rods and generally, ware patterns in .000.
Mark
   / Engine Rebuild
I just did the upper end. Took rods & pistons out and checked rod throws on the crank they were standard, didn't do anything to mains since the oil pressure was 35psi at idle. There was no wear on the bore. I have seen other engines with a wear lip you could hook your fingernail on but this engine had no wear at all. I honed the cylinders good, cleaned the pistons, installed rings then slipped pistons in cylinder.
I only have one very small water leak at the top of the water pump where the sensor for the temperature guage goes, just a little tightening.
   / Engine Rebuild #19
"I only have one very small water leak at the top of the water pump where the sensor for the temperature guage goes, just a little tightening."
I would use plumber's thread sealant, tape or silicone sealant on that.
   / Engine Rebuild
Here's what the old rings looked like in the cylinder.
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2022 JOHN DEERE 320G WHEELED SKID STEER (A51242)
2022 JOHN DEERE...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
Roose Hog Cart (A50515)
Roose Hog Cart...
Kohler Generator (A50322)
Kohler Generator...
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A52128)
2018 Ram 3500...
