Essential tractor features
   / Essential tractor features #21
,. ,,,,,Ample cooling for 100% load.
If running at 100% is a concern I would be looking for a bigger tractor to start with.
   / Essential tractor features #22
In order of preference:
Orange
Cab with HVAC
Hydro
4WD
FEL w/ SSQA
3d function
Top and Tilt
Extendable lower arms
Steering wheel spinner
Rear camera
   / Essential tractor features #23
Without duplicating what everyone's said, I would add a rear work light.
More lights up front the better but rear is essential to me.
Good one! Only 2 of my tractors have this, and the mental relief using them at nite is almost blissful.
   / Essential tractor features #24
adding to...
either welded on or bolt on bucket hooks. from FEL (front end loader) to backhoe buckets. they need hooks on them for chains / ropes / straps.
small little tool box. with some sort of good lock. such as what many ammo box latchs are like. so the lid stays close. just big enough to hold a hammer, some baling wire, some pins, pair of channel locks, some wire cutters. other words just enough stuff. to limp back to the shed. when something happens. and being able to wire things up. to adjusting the turn buckles on 3pt hitch when they get rather stubborn. to removing pins / inserting pins when hooking stuff up / un-hooking stuff.
return to position for 3pt hitch.
   / Essential tractor features #25
Cool thread. Read all the posts, and there you go- the complete tractor setup! Of course, no everyone needs everything, but at least this is a good starting point for consideration.
   / Essential tractor features #26
I'd add front worklights, the headlights have a hard time with the loader. Also, if the tractor has a clutch, HST pedal (s), and brakes, the clutch and HST should be on the right, the brakes on the left, so you can use them without the cruise control on. Finally, I'd re-emphasize position control, I will never buy a tractor without it.
Now this thread just needs to get to some manufacturers.
   / Essential tractor features #27
I would add a quick hitch for me and cruise control.
And a suspension seat and rear lock diff.
Does a quick hitch work with the telescoping arms. It seems like it would cancel it out.
   / Essential tractor features #28
It will work fine. But the telescoping lower links are just left telescoped in. They are of no significance at that point. To really make the best use of a quick hitch you need hydraulic top link too. So you can line up the top hook better. Of course hooking up on flat ground helps in all cases, quick hitch, telescoping links or solid links.
   / Essential tractor features #30
Wow lots of fancy things
This is me and my family-
Preferred wide front
Hydraulics
Running
Decent tires
Preferred which color matches the price and that's usually Allis Chalmers
We have not really paid more then $2,000. I guess gig can say we are poor people lol
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
HYUNDAI 740-9 (A52472)
INSPECTION (A51573)
INSPECTION (A51573)
