estimated cycle times (log splitter)
   / estimated cycle times (log splitter) #11
I've always figured that the cycle time on my splitter was a little slow, but as long as it was faster than my helpers (or my ambition) there was no problem. I've never really timed it but 12 seconds does seem a little slow however....
   / estimated cycle times (log splitter) #12
IMO, cycle time is not a relevant number since, most cycles are interrupted somewhere half way through the log, and all suddenly cycle time is cut in half.
Extend and retract velocity, inch/sec, is a better way to compare performance on a splitter. That would also eliminate the possible "error", when comparing splitters with different length of stroke.
Why "cycle time" is so rooted in peoples mind now? Probably because it is easier to clock cycle time than measuring speed.
Just curious....
I do not know how you got that "13.6"-number??Do you have "some mouth to mouth" information, or some facts that can be backed up, that I have missed. Maybe a discontinued pump model?
Haldex-Barnes pump with nominal flow 13 gpm, flows 13.11 gpm at 3600 rpm.
Math:
displacement on the two pump units are 0.194+0.647=0.841 cui.
Out put flow will then be 0.841 x 3600=3,027.6 cui/min>>3,027.6/231=13.11 gpm
That is the theoretical flow, which will be reduced when internal leakage gets counted into the equation. Volumetric efficiency is not posted in the H&B pdf, can be expected to be between 85-95% with a 300SSU/57cSt viscosity oil and at operating pressure.
Since high flow is at a lower pressure, I would "guesstimate" eff to 95%, and actual high flow would then be about 13.11 x 0.95 = 12.5 gpm....
Not a big deal, but with wrong impression of real flow, it is easy to make a call for a bad pump....
Haldex Hydraulic Pump — 13.6 GPM, 2-Stage, Model# 1001506 | Pumps | Northern Tool + Equipment
2007 Ford Crown Victoria Passenger Car, VIN # 2FAHP71W77X101435 (A57453)
2007 Ford Crown...
1991 International 4900 Box Truck (A55315)
1991 International...
Polan 3400 Chainsaw (A57454)
Polan 3400...
208315 (A58376)
208315 (A58376)
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
