Ethanol, myths and realities
   / Ethanol, myths and realities #21
Cowboydoc,
</font><font color="blue" class="small">( The other factor not mentioned is that currently 200 bushel/acre corn is common. There are hybrid/genetic types that are capable of producing 400 bushel/acre with more energy content. )</font>
Do you know how many gallons of ethanal is produced by 200/400 bushels?
Later,
Dan
   / Ethanol, myths and realities #22
Cowboydoc,
Later,
Dan
   / Ethanol, myths and realities #23
Dan,
Here is an article that dispels the negative balance claims and tells you what you get out of a bushel of corn.
   / Ethanol, myths and realities #24
Dan,
   / Ethanol, myths and realities #25
Richard,
I did not see a direct answer to how many bushels of corn it takes to make a gallon of Ethanol but reading here and there on the various links I found the following....
A gallon of ethanol has at least 77,000 BTUs. A bushel of cord produces 46,137 BTUs of ethanol.
Soooo, it takes 1.7 bushels of corn to make a gallon of ethanol.
And if the acre produces 200 bushels of corn that is 117.7 gallons per acre.
I would guess that these number are low since I found some of the information in article from 10 years ago.
I know a gallon of ethanol is not a gallon of diesel but I use roughly 1200 gallons of diesel a year. So I need to go plant 10 or 12 acres of corn. Or 5 or 6 if a hybrid. /forums/images/graemlins/grin.gif
Later,
Dan
   / Ethanol, myths and realities #26
Richard,
Later,
Dan
   / Ethanol, myths and realities #27
""Soooo, it takes 1.7 bushels of corn to make a gallon of ethanol.""
Is this like saying $2/bu corn is equivalent to $3.40/gal for ethanol?
Something doesn't add up here. The farmers are going to want more for the corn, it takes $$ to convert the corn to ethanol, and the ethanol buyers are not going to want to pay over $3/gal. But I may be missing something. /forums/images/graemlins/tongue.gif
   / Ethanol, myths and realities #28
   / Ethanol, myths and realities #29
The most efficient way to produce ethyl alcohol in megagallon quantities is not to use any corn at all, just use 100% garbage refuse wastes. Use genitically modified recombinant E.coli with a selected transgene for ethyl alcohol production in the glucose fermentation cycle...... way more bang for your buck!!! /forums/images/graemlins/laugh.gif
   / Ethanol, myths and realities #30
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Utility Trailer (A52377)
Utility Trailer...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
