Ethanol, myths and realities
   / Ethanol, myths and realities #21
Cowboydoc,
</font><font color="blue" class="small">( The other factor not mentioned is that currently 200 bushel/acre corn is common. There are hybrid/genetic types that are capable of producing 400 bushel/acre with more energy content. )</font>
Do you know how many gallons of ethanal is produced by 200/400 bushels?
Later,
Dan
   / Ethanol, myths and realities #22
Cowboydoc,
Later,
Dan
   / Ethanol, myths and realities #23
Dan,
Here is an article that dispels the negative balance claims and tells you what you get out of a bushel of corn.
   / Ethanol, myths and realities #24
Dan,
   / Ethanol, myths and realities #25
Richard,
I did not see a direct answer to how many bushels of corn it takes to make a gallon of Ethanol but reading here and there on the various links I found the following....
A gallon of ethanol has at least 77,000 BTUs. A bushel of cord produces 46,137 BTUs of ethanol.
Soooo, it takes 1.7 bushels of corn to make a gallon of ethanol.
And if the acre produces 200 bushels of corn that is 117.7 gallons per acre.
I would guess that these number are low since I found some of the information in article from 10 years ago.
I know a gallon of ethanol is not a gallon of diesel but I use roughly 1200 gallons of diesel a year. So I need to go plant 10 or 12 acres of corn. Or 5 or 6 if a hybrid. /forums/images/graemlins/grin.gif
Later,
Dan
   / Ethanol, myths and realities #26
Richard,
Later,
Dan
   / Ethanol, myths and realities #27
""Soooo, it takes 1.7 bushels of corn to make a gallon of ethanol.""
Is this like saying $2/bu corn is equivalent to $3.40/gal for ethanol?
Something doesn't add up here. The farmers are going to want more for the corn, it takes $$ to convert the corn to ethanol, and the ethanol buyers are not going to want to pay over $3/gal. But I may be missing something. /forums/images/graemlins/tongue.gif
   / Ethanol, myths and realities #28
   / Ethanol, myths and realities #29
The most efficient way to produce ethyl alcohol in megagallon quantities is not to use any corn at all, just use 100% garbage refuse wastes. Use genitically modified recombinant E.coli with a selected transgene for ethyl alcohol production in the glucose fermentation cycle...... way more bang for your buck!!! /forums/images/graemlins/laugh.gif
   / Ethanol, myths and realities #30
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
200387 (A51247)
200387 (A51247)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
