Ever regretted buying something? Be honest...
   / Ever regretted buying something? Be honest... #1
Alien
Elite Member
Grantham, South East Queensland
Kioti CK30 HST
About 20 years ago I bought a small 4x4 and decided that maybe a winch could be useful as I often went 'bush' gold hunting.
Well I never got around to fitting it and then I sold the 4x4 and forgot about the winch until I found it today.
I hooked it up to a battery to see if it worked and it ran OK but I have no idea what I am going to do with it now....
   / Ever regretted buying something? Be honest... #2
In my back bedroom - a brand new jet pump. Ten years ago I converted to a submersible pump for the house well. It was to be used as a spare.
   / Ever regretted buying something? Be honest... #3
What is this, a trick question? Of course I've bought stuff and then regretted it... but I'm a sucker for a gadget that I might use sometime in the future.
In a way I'm glad that this year everything is shut down, especially AGFEST, were I'd inevitably buy things that 'I never knew that I needed!'
But I've GOT them. (lifting strops, nibbler, clamp set, tripod light, dremmel kit, solar lighting kit, oh the list does go on...)
   / Ever regretted buying something? Be honest... #4
Boy! I don't know if I could list all those times!
Not so much the tractors and equipment...I like my 4520, but I wish I could have swung something with a factory cab rather then an aftermarket (Curtis Cab)
   / Ever regretted buying something? Be honest... #5
Buying a MX6 mower Feb.2008 and not use until the field needed mowing and have the bottom fall out with a broken shaft.
no warranty or parts.
purchased a used worn Bush hog brand .and have mowed this past 12 years only needing to be greased.
put a sower taste in mouth on any other J.D. equipment.
   / Ever regretted buying something? Be honest... #6
I couldn't begin to guess how many times I've done that. I have a winch and windshield for my last ATV which never have been used. I bought the windshield in 2000 or 2001.
There are so many projects I've planned but never found the time or know-how to do; I'm reminded every time I clean my shed.
   / Ever regretted buying something? Be honest... #7
A small 18k disc that cost me over $600k.
   / Ever regretted buying something? Be honest... #8
There are always regrets when buying something. Especially since there is usually no cut and dried ' perfect ' answer in what you should buy. Life is a journey of choices. The trick is to stay around as long as possible to make lots of good/bad choices. And to be able to keep your wits about you to be able to be atch a boot it..... STAY SAFE
   / Ever regretted buying something? Be honest... #9
Yep, been lots and lots of things that I've bought and later regretted, but the worst in my lifetime was when I bought a new 1966 Ford Fairlane that I'm sure was the worst lemon Ford ever produced.
2015 DODGE RAM...
2014 MACK GU713 WATER TRUCK (A51243)
2014 MACK GU713...
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2018 VOLVO VNL SLEEPER (A51222)
2018 VOLVO VNL...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
