Excavator hydraulic pump help ?
   / Excavator hydraulic pump help ?
One thing I just noticed was on the reservoir if I pick the boom up all the way it draws a vacuum on the reservoir. It’s only a slight vacuum as is barely moves it off the zero mark. If I’m using most other functions it seems to slightly pressure the tank. Is this normal?
   / Excavator hydraulic pump help ? #52
Were you extending one or more cylinders when raising the boom? If yes you would be drawing more oil out of reservoir than being returned so possibly would see slight vacuum.
which pump failed, one with case drain hose connected to that end or opposite end?
The side with the case drain hose failed. The drain is at the bottom side of the case. The machine was parked. I fired it up and was at low rpm. Moved it about 5 feet and it went bang. I never expected it and there was no sign of any problem. It probably had 25 hours on the pump. Fresh filters and oil.
   / Excavator hydraulic pump help ? #54
Hey I have a yuchia grey market mini sounds a lot like yours. Do you have a rexroth ap2 pump? Any update on how your machines going?
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
2016 CATERPILLAR 950M WHEEL LOADER (A52705)
2016 CATERPILLAR...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2017 FREIGHTLINER...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
24637 (A55853)
24637 (A55853)
