Excessive Grease in Axle Housing
   / Excessive Grease in Axle Housing #1
fembot54
L3130
What happens if excessive amounts of grease get pumped into the axle housing of an L Series via the rear axle support zerk fitting and how can it be removed??
   / Excessive Grease in Axle Housing #2
You end up getting grease in your gear oil. Its not like grease isnt a lubricant, so its not that big of a deal. You are only putting a bit of grease into a fair bit of gear or hydraulic oil. I run an old flail mower gearbox with failed seals on pure grease.
   / Excessive Grease in Axle Housing #3
Check the parts catalog for that model, there is no path for the grease to go between the pivot point and the inside of the front differential. That used to be the case on some older models, specially B series. My old B7000 was like that.
Forcing too much grease the front axle pivot points on most tractors results in blowing the o-ring that seals the pivot points. These Japanese and Korean tractors are built for rice paddies, meaning the tractors are ran buried all the way to the axles, so they want to prevent water and mud to get inside those pivot points, hence the o-ring.
It's not an huge deal blowing that o-ring out if you're not working on rice paddies but it still prevents water, moisture and dirt from sneaking in.
24ft Corral Panel (A47809)
24ft Corral Panel...
2015 CHEVROLET SILVERADO 3500HD FLATBED (A47001)
2015 CHEVROLET...
John Deere 2950 4WD Tractor (A47809)
John Deere 2950...
72in Bucket (A47809)
2017 FREIGHTLINER CASCADIA SLEEPER TRUCK (A45676)
2017 FREIGHTLINER...
Northstar 8000TFG Generator (A45336)
Northstar 8000TFG...
