Exhaust coming from breather tube & Dip Stick?
   / Exhaust coming from breather tube & Dip Stick? #1
gt14
Aumsville Oregon
Yanmar YM146 YM165D
I have a 2 cylinder diesel YM146 Yanmar. I have exhaust smoke coning out of dip stick hole and the breather vent tube. Oil has also been coming out. Any ideas what could cause this?
   / Exhaust coming from breather tube & Dip Stick? #2
I would say bad or broken ring/rings
   / Exhaust coming from breather tube & Dip Stick? #3
I agree. Something is causing excess pressure in the crank case.
   / Exhaust coming from breather tube & Dip Stick? #4
Male sure oil is not overfilled. If oil is dirty, change it, (seems like this only happpens with dirty oil). Make sure dipstick seal is good. Make sure muffler is not plugged up.
   / Exhaust coming from breather tube & Dip Stick? #5
This is so called "blowby" caused either, broken\colapsed compression rings. Go with thicker oil, and don't overfill. I would not worry to much about if its an older engine, if is not, I would teardown and replace rings.. Good luck.
   / Exhaust coming from breather tube & Dip Stick? #6
Think it's time for a compression check and then repair/rebuild time! /forums/images/graemlins/frown.gif
Egon /forums/images/graemlins/grin.gif
Thank you for the comments I will get heavier wt oil and do a rebuild after the season.
When I drained the oil it had a fuel smell to it and it was very thin. I suspect fuel in the oil. What does this mean?
   / Exhaust coming from breather tube & Dip Stick? #9
Rings!
A compression check will confirm.
But on the offchance that the rings are stuck (would be generally the same symptoms) you might always try soaking the rings with some sort of penetration or cleaner solution.
Folks would often use various 'patetented' upper cylinder addetives to loosten up rings such as Whinns or Bardhall.
Other than a few dollars, there is not much to loose.
Generally they mix with the fuel and I have actually seen some good results.
Good luck!
   / Exhaust coming from breather tube & Dip Stick? #10
Pull the oil filler cap off, crank it up. Watch for blowby and place your hand over it to see how much pressure. Good luck.
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
New/Unused AGT YSRT14 Mini Skid Steer Loader (A51573)
New/Unused AGT...
