Exhaust coming from breather tube & Dip Stick?
   / Exhaust coming from breather tube & Dip Stick? #11
You got fual leaking into the crankcase from either the pump or injectors.
   / Exhaust coming from breather tube & Dip Stick? #12
Does your motor have sleeves? If not a check sooner than later may save a block.
Egon /forums/images/graemlins/grin.gif
   / Exhaust coming from breather tube & Dip Stick? #13
Change the oil, turn off the fuel shut-off valve everytime you shut down the tractor, and I'll bet your problem will go away. Use Shell Rotella T 15-40 heavy duty oil, and you should check the oil everytime you use the tractor to make sure it's not using or "making" oil.
   / Exhaust coming from breather tube & Dip Stick? #14
You can also use amsoil 15w-40 heavy duty diesel oil. Better numbers than rotella t But ,I'll bet it's time for a rebuild.
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
