Re: outdoor woodburners? / garages
<blockquote><font size=1>In reply to:</font><hr>
Wonder what Anderson's manufacturer says!?
<hr></blockquote>
The model I own is specifically made for indoor installations, and calls for a minimum of 6" clearance between the boiler, and combustible materials. I have reviewed local codes, as well as the installation instructions, and am convinced that I have a legal, and safe unit. There are redundant aquastats on the draft motor, a heat dump relay connected my indoor furnace, and of course the pressure relief valve on the boiler jacket.
I have the luxury of storing my grill on the deck, and all lawn tools, and gasoline storage containers in my pole barn. As for parking cars in the garage, I'm not worried at all - our cars don't leak gas.
Larry, you are correct about ashes and embers falling out of the burner, that's why I sweep the area around the burner a couple times a week, so there's nothing for the stray embers to ignite.
An outdoor unit could have a spark blow into the grass and start a grass fire an hour after you leave. An indoor unit could have a pop, send an ember 5 feet away into the wood pile, and start a fire an hour later. A standard natural gas or propanem furnace could leak gas into your home and blow up your home, or have combustion problems, leak CO, and kill you in your sleep. You could electrocute yourself working on electrical resistance baseboard heaters. I don't think I need to get into indoor fireplaces. When you work with energy, there is always a possibility of something going wrong. Be careful, and think about what you are doing.
This morning it was -5 outside, and 40 in the garage. The cats like it, I like it, and it is a safe system when operated properly.
Trying to keep warm in MN
Nate
