Experience with Tank-less water Heaters
   / Experience with Tank-less water Heaters #11
Another good vote for for Rinnai. We had a NG unit installed in our (wife and I) new home's garage which we took possession on 11/15. The water heater has been 100% reliable and our NG bills are small. Another consideration is installing multiple smaller units if the size of the house warrants it due to long pipe runs and wasting a lot of water waiting for the hot water to get to the faucet.
   / Experience with Tank-less water Heaters #12
Search TBN for more discussions about tank less water heaters. There have been a few and seems like some discussions were quite long.
We thought about putting in a tank less water heater but we decided against it for a couple of reasons.
  • It would have to be electric and the temperature rise was iffy.
  • It was far cheaper to have an 80 gallon water heater.
  • The 80 gallon water heater is a nice source of water if we are out of power.
Years after we moved into our house, we were talking to our plumber. He said he now refuses to install a tank less water heater since he had so many problems with them. The big problem was water hardness. So if you do put in a tank less water heater, I would make sure the water supply was in spec for the heater. Hopefully the tank less water heaters specify water quality.
Later,
Dan
80 gallon electric water heaters are no longer available for residential use unless they are heat pump units, and that's a whole other discussion.
   / Experience with Tank-less water Heaters #13
We have three Rheem LP units, one is about 3 years old now and the other two are about 4 months in use. I love them, cheap, efficient and endless hot water. It is very important that you flush them with vinegar or similar solution to remove the scale. All three of our units have the service valves that make this procedure simple. The upfront cost is high but the long term value is there.
   / Experience with Tank-less water Heaters #14
Either LP or NG gas type Bosch and Rinnai gas type i am familiar with and both are good units. Just go ahead and get the flush valves installed when the unit is installed. Its so much easier and simpler to do so at original install.
Probably does not matter at this time but just so you know some areas are beginning to require high efficiency hot water heaters and some Hvac units to have the condensate drain go to a separate drain point, usually a very small gravel pit near the edge of the house. The ph is so different they do not want them draining into the septic system or the municipal treatment plant. I think this will become national code in a few years from what I am told.
Thanks a lot for all the info. This has narrowed my choice to Rinnai or Rheem. They are close to the same price for the top of line; high, but this is a long term investment.
Ron
   / Experience with Tank-less water Heaters #16
Ron
just an FYI. Most all of them are made / use with the same components. Not a nickles worth a difference in any of them
   / Experience with Tank-less water Heaters #17
We are about half way to closing on our new house. I want to convert to a whole house tank-less WH and looking for voices of experience. will be natural gas direct vent condensing type. I have boiled it down to 3 brands; Rheem, Bosch, and Rennai in their top of line. I am more interested in life and problems than cost.
Who out their has experience with these brands? How long has it been in? Problems? Would you recommend it to your best friend? Any help will be appreciated. Thanks in advance.
Ron
We've had a Rennai for over 6 years. When we bought this place (3000 sq.ft.) we had a brand new electric water heater jerked out and replaced with a propane/electric start tankless heater. Best move we've ever made. Endless hot water, no idle time heating cost, and essentially maintenance free. The unit cost us $1600 installed.
Ours is mounted on an outside wall near the bathrooms. No venting problem and never have had a freezing problem... Having hot water for a quick shower is actually 'quick'. As far as maintenance, ours has two bypass plugs to take out, run the water a few minutes through it to flush any residual that might be in there, and replace the plugs. Very simple process that we do about every couple of years.
My only two suggestions are that when you do have it installed, try to locate the unit as central as you can conveniently locate it. AND - add a small unit under the kitchen sink. Wife doesn't like to wait 30 seconds for hot water to go from the unit to the sink. The little one location unit is only about 1 foot square and cost a couple hundred dollars. They also only use 120v electricity to spark the heating coil. Low cost for a happy wife :)
   / Experience with Tank-less water Heaters #18
Ron
Make sure you order the service valves with them, they make de-scaling the units so much easier.
   / Experience with Tank-less water Heaters #19
We have a Noritz that is 7 years old now and installed the recommended filter with it. The filter needs to be changed every3 years and is around $ 125. The only problem we've had is one of the wires from the control panel to the computer apparently vibrated loose causing an intermittent fault message .
Ours is used as back up to our solar water heater and so far is very satisfactory.We would never go back to the old tank type heater.
   / Experience with Tank-less water Heaters #20
-1 for Bosch and + 1 for Rinnai
First installed a Bosch. It was still under warranty when the control board failed. I called their support line multiple times, they asked me to do lots of stuff to test. In the end they called it "electrical failure at customer's home" whatever that meant and refused to honor their warranty. Mind you, nothing else failed in my house and the electrical part of the unit was a simple plug in to an outlet. Replacing the control board would have cost me $800. I decided to scrap it instead and replaced it with a Rinnai. Haven't had a lick of problem since. There is a reason why there is no Bosch service guy in my little town while I can find several outfits that will service Rinnai systems.
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
(6) ROLLS OF MISC LINOLEUM (A54757)
(6) ROLLS OF MISC...
2013 INTERNATIONAL REEFER TRUCK (A54607)
2013 INTERNATIONAL...
Ford Pickup NR (A50323)
Ford Pickup NR...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2013 CATERPILLAR D5K2 XL CRAWLER DOZER (A52705)
2013 CATERPILLAR...
