Exploded diagram for Vicker pump off Ford NAA
   / Exploded diagram for Vicker pump off Ford NAA
I called Attica...over $800 with a $372 dollar core....My local guy is looking with his suppliers and thought he could get a pump for around $150.00. Mean time I put it together with the new seal and front bearing It is installed on the tractor and is running. Loader cycles just fine. It still can lift the front end of the tractor off the ground. Seal is dry and all my refit plumbing looks good too. I did find that the filter housing was mounted backwards from the direction of the arrow so I reconfigured things make the flow follow the arrow.
   / Exploded diagram for Vicker pump off Ford NAA #22
so, i have this same pump on my ford.....the center housing cracked on both sides after adding new hoses and oil to the reservoir. did i mess up by not letting the air out before i started the engine?
any ideas plus a source for the housing would be greatly appreciated.
many thanks,
guil
Not sure where you are but my guy is mdm hydraulics in salem oregon. Also try surplus center for replacement pumps.
   / Exploded diagram for Vicker pump off Ford NAA #24
so, i have this same pump on my ford.....the center housing cracked on both sides after adding new hoses and oil to the reservoir. did i mess up by not letting the air out before i started the engine?l
Those housings break only from a severe pressure spike, usually from deadheading the pump.......better check your hose connections before you fire that up again or you may need another housing after
Air purges itself through start up and ends up in the reservoir......also don't forget to clean the suction screen at the tank
   / Exploded diagram for Vicker pump off Ford NAA #25
Many thanks for the response! I have spoken to your guy in Salem and may send the pump to him. What's the salvage center?
cheers,
guil
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2024 AGT LRT23 Mini Stand-on Track Loader Skid Steer (A56857)
2024 AGT LRT23...
2020 DRAGON ESP...
