externally regulated alternator question
   / externally regulated alternator question #21
if it runs with your quick change in power wire setup. and you were just interested in getting it running.. i would think the addition of another switch inline would be the FAST , EASY way to get it done.. ( remember.. fast and easy are the path to the dark side per yoda ;) )
well i pretty much live on the dark side. :laughing: Try to stay on the lighter end of the dark side however!
i think i try a relay that is triggered by the ignition switch and mount it next to the regulator with an inline fuse. All stuff I have in my electric bin, 10 minutes of work.
i messed with the wiring at the switch, but couldnt make the charging system work that way. I took a wire and ran it from my acc post on the switch directly to the red wire on the regulator and now it charges at 14.03 volts across the rev range like it should. Has no draw with the key off. Only downfall is my charing light does not work, not ideal. The oil pressure light is the one I really care about.
   / externally regulated alternator question #24
if the charge lamp doesn't work.. I still think you have a problem in the wire harness or a bad connection.
it did work before, but i have the red wire at the alternator cut and capped on the harness end with power feeding into it on the regulator end from my accessory switch, so i didnt expect it to work now.
I agree, there is a wiring problem somewhere, or many problems. Literally nothing worked except the started on this thing when I got this, and that actually stopped working when the switch died.
Diesels sure allow you to get lazy on the electrical side. Ideally id like to just redo most of the harness, its pretty darn simple really. If I had my hand on a wiring diagram it would be no issue at all!
For now it charges and the oil pressure light works, so I have the necessities to keep doing work.
   / externally regulated alternator question #26
We used to have a Ford 1900 that developed similar problems. We were able to get it charging when we replaced the ignition switch but it still had a "drain" problem. Never could locate it. Our fix was simple. We got a "battery switch" that installs on the positive battery post and the battery cable connects to that. You turn the switch when you park and the battery is no longer connected. Turn the switch back when you want to use the tractor.
Of course, the battery was right in the front and easy to get to.
Worked just fine till we traded that tractor for something bigger.
   / externally regulated alternator question #27
14.03 volts across the rev range is acceptable, but 14.25-14.5 is better 15.0+ is pushing the upper end of output.
You could add an oil pressure gauge which would be more useful than a replace engine light.
replace engine light, I LIKE THAT!:laughing:
I would like to have a gauge and a good coolant temp gauge too.
   / externally regulated alternator question #29
An oil pressure gauge needle sitting at zero won't catch your eye like a red light.
What's not "good" about your current temp gauge?
current temp gauge needs to be replaced i think. There is power to it, sender gives the right ohm readings and changes as it warms up, wiring is good to gauge. When I say nothing electrical worked on this tractor, i mean absolutely nothing.
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2023 HELI CPYD25C FORKLIFT (A58214)
2023 HELI CPYD25C...
Kawasaki NR (A50324)
2022 Club Car Tempo Golf Cart (A55853)
2022 Club Car...
2019 GEHL RT105 SKID STEER (A52707)
2019 GEHL RT105...
2007 Ford Focus Hatchback (A54815)
2007 Ford Focus...
