jejeosborne
Veteran Member
Yeah, still not impressed.
Although, that HEMI still looks great making more power with a tried and true simple engine running over 9 years now of proven reliability yet only given up 2 mpg average. Considering there's no turbos or direct injectors to worry about is the icing on the cake. With the new 8 speed auto, that HEMI will match or beat that 16/22 mpg, then I will be even more unimpressed. :laughing:
Also, you should show the Ford V8 5.0l to really make the Ecoboost look unimpressive...
Ford 5.0 liter 15/21 360 hp / 380 lb.ft.
Now that 5.0l from Ford DOES impress me.
Sorry but the total power output from the ecoboost is greater by a pretty good margin over the hemi. Where are you getting your information? I am also giving the benefit of only discussing peak numbers. I will tell you this for about the 4th time, look at the area under the torque curves. Would you agree that is the important information?
http://blogs.insideline.com/straightline/assets/Ecoboost-vs-Ram.jpg
Dyno-Tested: 2011 Ford F-150 Ecoboost
Impressive?
The ecoboost gets 10% better mileage and 3% better torque. As far as other comparisons:
5.0 liter Ford gets 4% worse gas mileage and 10% less torque
6.2 liter Ford gets 22% worse mileage but only 3% better torque
3.7 liter Ford gets 9% better mileage but 51% less torque.
The ecoboost makes 420 lbs-ft at 2500 rpms. Yeah, enjoy your 407 lbs-ft at 4000 rpms. In addition the hemi doesn't pass the ecoboost in HP either until it hits around 5200 rpms. Who operates their trucks in these rpm ranges? I guess anyone without a diesel or ecoboost.
The Hemi required 89 octane fuel to achieve rated numbers vs the ecoboost on 87 octane. In fact most Hemi owners use 89 octane in every tank to prevent engine damage. Do you?
Impressive?
I am with you in that the 2013 model looks promising and if it proves as successful as the ecoboost, I will support it as well. I am definately not brand loyal, just appreciate good products from anyone.
Hopefully they keep making the Ram truck and engines in Mexico and not by these clowns. Chrysler Workers in Trenton Caught Smoking and Drinking During Lunch Breaks
Entertaining video. This is the second plant they have busted in recent history.
NOT IMPRESSIVE!!
