F-150 Valve Tappets(?)
/ F-150 Valve Tappets(?) #1
CurlyDave
Elite Member
Grants Pass, OR
JD TLB 110
I have a 2000 F-150 with the V-8 Triton engine, right now 75k miles.
Based on some threads on TBN, about 2k miles ago, I changed the oil to RotellaT 5W-40 synthetic.
Almost immediately I started hearing a noise which I have always associated with valve tappets (rat-tat-tat-tat-tat...). Almost like a muffler noise, but primarily under load, especially when cold. Warm it up or stop going uphill and the engine is silent.
Who knows if the Triton engine even has valve tappets?
Is this the right diagnosis?
Is this harmful to the engine?
Could changing from Mobil 1 5W-30 to the RotellaT 5W-40 cause this, or is that just a coincidence?
Is it bad enough for the engine that I should immediately change the oil again, or can I let it go for a few weeks? (Deer season is in 3 weeks, and frequently we drive hundreds of miles in a dust bowl and I am going to change oil after that anyway.)
Should I try adding some kind of "mouse milk" to the oil to quiet this down?
Cost is a consideration, but I can buy a lot of oil for what an overhaul will cost.
/ F-150 Valve Tappets(?) #2
Yeppers the ford lifters are noisy. In our 2003 F150 we run 5w20,. I only run the Mobil 1 synth. Thats the spec for ours. Not sure about yours but i think its 5w20 too,
Running the Mobil makes a big difference in valvetrain noise.
I think theres a ford TSB on the issue. If memory serves, the recomended fix is proper synth oil. Of course they recommended the Motorcraft oil. Also use a good filter. I like the motorcraft ones
One other remote thing, Check your plugs for loose or ejected ones.
Does it seem to be on one side or the other? Our truck had a blown header gasket / broken bolts that caused a bad ticking noise especially under load up hills. Both the plugs and the manifolds are known issues that ford chooses to ignore.
If you have a blown gasket, youll likely have a warped header and broken bolts. For giggles i got a quote from the dealer, 1200 is the typical minimum. Usually they have to pull the head > $2000!!! Its a major PITA job that took me over a day, Theres no clearance between the frame and the head to get a normal drill in. I replaced the studs with stanless bolts so this shouldnt happen again.
Good luck. Hope its nothing major/
/ F-150 Valve Tappets(?) #3
I am trying to remember here but that era engine called for 5W30 oil. I do not think they recommended 5W20 until the body change over in 04 ish model year. I would think its the the oil you are using is just too heavy. I would go back to a 5W30 or what it calls for and see if it goes away.
Chris
/ F-150 Valve Tappets(?) #4
Chris
My 2003 is 5w-20.
/ F-150 Valve Tappets(?) #5
Hydraulic lifters probably aren't filling properly due to lower viscosity???:D:confused::confused::confused:
My manual is 400 miles away, but I remember it calls for 5W-30.
I didn't think a minor change like that would have that big an effect.
Anyway, the remaining question is can I wait a month to change it, or should I do it right away, knowing that another change is coming up in a month anyway?
I can live with the noise if it isn't doing any permanent harm to the engine.
/ F-150 Valve Tappets(?) #8
viscosity can make a big difference in this engine, in my experience. Id go back to proper spec mobil 1 and see what happens.
Id also have a look around for the things i mentioned in my otherpost.
Will you do damage? Hard to say, likely not, but the spec is the spec for a reason, so i wouldnt chance it personally.
/ F-150 Valve Tappets(?) #9
My 2001 F150 had the 5W-20 recommendation and my 97 did not. Same exact truck except the 01 was an automatic.
Dave,
There is a pretty significant viscosity difference betwen the Rotella (heavy diesel rated oil on the thicker side of the 40 weight scale) and Mobil 1 5w-30 (lighter 5w-30 that is very close to the the semi -synthetics 5w-20). Your results are the exact same as I recall on both of my Fords and currently on my GMC (which also has Rotella 5w-40 in it right now). Cooler weather will obviously make the ticking last longer as the engine takes a little longer to warm up. In the mean time, run it. Sounds like you have a lot of extended driving to do, which is a much better situtation that a bunch of short trips. Once your trip is over go back to a lighter 5w-30 like Mobil 1 or even the Motorcraft stuff. Last time I checked the Motorcraft oil was a Chevron Group III based oil and has very good wear results. As good and sometimes better than M1. I have gotten most of my info from BITOG, but haven't been back on those boards in a while.
/ F-150 Valve Tappets(?) #10
I would also say go back to the recommended oil right away. Its not worth $30 in oil taking the chance of blowing up a $4000 engine. I always use the Motorcraft Semi Synthetic in all my Fords. Its the best price stuff on the market. I get it from my dealer for less than I can get it at WalMart.
Chris
/ F-150 Valve Tappets(?) #11
I would suggest the oil change but my knowledge is limited.:confused:
The lifters will not stay full so your valves will opening late, closing early and not opening fully. Not by very much though. The clacking should be because of the slight gap between the follower and the valve stem??
/ F-150 Valve Tappets(?) #12
Take a stethiscope or long screwdriver and listen to the valve covers and all over the engine this will help you track the "noise" down.
/ F-150 Valve Tappets(?) #13
I checked the 2000 F150 manual
https://www.fleet.ford.com/maintenance/owners_manuals/results.asp
It calls for 5W20 super premium motor oil.
Same as my 2001 F150. My Ford dealer handles my lube needs and refills with Motorcraft 5W20 QSP oil.
/ F-150 Valve Tappets(?) #14
I would change the oil again . Otherwise you are only assuming it is oil viscosity related . It could be something more serious and until you change the oil to rule it out as the cause , you will only be guessing .
/ F-150 Valve Tappets(?) #15
I'm with Scooby074.......Both the plugs and the manifolds are known issues in the 5.4 Triton pre 2003. Google blown sparkplugs in these engines. I have a 1999 but it just turned 70,000 miles and so far so good.
/ F-150 Valve Tappets(?) #16
Interesting.
I'm wondering how common that sparkplug blowout problem is.
/ F-150 Valve Tappets(?) #17
Interesting.
Main problem was lack of threads on the spark plugs and idiots over torquing them. Some had as little as 3 threads. I have owned 10 plus Ford trucks and my family has had another 10 and none of us ever had a problem but guys who change the plugs and cross thread them or over torque, most spark plugs need only 7-10 pounds of torque which is very little, had problems. People over torque them and strip them out and they blew. To combat this Ford redesigned the head to fix the issue around the 03 model year.
Chris
/ F-150 Valve Tappets(?) #18
Chris
Thanks for the info, Chris.
I ask because I'm shopping for a one-ton flat bed truck, F350 or equivalent, 1995-2000 vintage. These typically have well over 100K miles on them which make me wonder if this sparkplug blowout problem is relate to high milage. Or is it just due to screwups in replacing and tightening plugs?
Researching this problem I discovered that undertightening the plugs can cause blowout too since the loose plug apparently hammers the threads in the aluminum head causing them to fail.
/ F-150 Valve Tappets(?) #19
I've wanted to change my plugs for awhile but it runs ok and not only it being a pretty tough job to get to some plugs think i'll go on if it ain't broke don't fix it.
/ F-150 Valve Tappets(?) #20
If it started the very day you switched to what admittedly is a wee bit out of range of recommended oil for that engine, why indeed wonder any longer?
Neither Ford, Honda or most OEM's have recommended anything close to that Xw40 spec for an awfully long time.
Drain the stuff, go back to what you were using. If the sound persists, you aren't any better off, but if it goes away, Bingo! problem solved for the cost of a jug of oil. Yup, our family has this same truck in the fleet. The other weaknesses are pretty well known. Still, a good truck though.:)
Eagle Weathervane (A61569)
Eagle Weathervane...
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
2018 F550 Bucket Truck (A63118)
2018 F550 Bucket...
2006 Isuzu NPR-HD Crew Cab Landscape Dump Truck (A61568)
2006 Isuzu NPR-HD...
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
Gehl RS5-19 (A62177)
