F735 diesel oil changr problems
   / F735 diesel oil changr problems #11
I doubt there will be any problem with the intake manifold. There should be a rubber line that will collect the crankcase fumes that comes right from the crankcase. Somewhere in on of those lines there must be a restriction. You may have to remove the aircleaner to get to it as it is likely in the v between the cylinders.
So I cleaned out the breather tubes this morning ( I pushed shop air through with no problem) but the same symptoms still exist. If anyone could help me get to the bottom of this problem it would be greatly appreciated Thanks
I finally had a chance to get to the bottom of this problem. Thanks to all of the input I got I kept looking into the problem with the breather tubes. I ended up taking off the intake manifold to get a good look at the breather tube port and found that it was completely blocked. I pulled out the clog which appeared to be a drill spiral of the black plastic that the manifold is made of. It may have been that way since the machine was new. Once I clear the blockage and reassembled the back pressure was no longer present. While I had the intake manifold off I noticed that he valve inside had a slight buildup on it. If that should be cleaned out are there any diesel additives that would help. Thanks for all the help.
   / F735 diesel oil changr problems #14
Unless it has significant build up I would not worry about it. I am glad you found the problem. Run a good fuel conditioner and you should be good.
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58018)
2018 FREIGHTLINER...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
Vermeer Mixing System with Hose Reel (A55973)
Vermeer Mixing...
