Failed Trailer Axle Brakes ... Near Miss!
   / Failed Trailer Axle Brakes ... Near Miss! #21
Trailer brakes are adjustable. Newer Dexter brakes MAY be self adjusting. Obviously, yours aren't. You may need to crawl under the trailer with a brake adjusting tool. I recommend jacking each wheel up, and adjusting untill the slightest bit of drag is felt when trying to turn the wheel.
The single most common electric brake problem is the very same thing that usually plagues electriclighting on a trailer.
THE GROUND!!!!!
Also, look to see if the brake wiring was done correctly from the factory. I bought a new 25' gooseneck about a year ago, only to find that the manufacturer decided to be creative, and wire the brakes different than Dexter recommends. They were only working about 50% untill I re-wired them.
You want your brakes to give you the feeling of a moderate "pull" with an empty trailer, at around 20 MPH, and the controller set at around 25%.
Speaking as someone who pulls gooseneck trailers around 40,000 miles a year, test them a couple times in the driveway BEFORE pulling out in traffic. The life you save may be your own....!
   / Failed Trailer Axle Brakes ... Near Miss! #22
</font><font color="blue" class="small">( Don; Those are good reasons why I don't loan out my trailers to anyone )</font>
See... if someone wants to borrow something.. stop and think for a minute.. *! Gee.. why don't they have one? ( because they probably can't take care of one! )
I hate when people ask to borrow something of mine.
Occasionally I will offer to be borrowed WITH my tools to help.. but not them without me.
Soundguy
   / Failed Trailer Axle Brakes ... Near Miss! #23
On my controller, I can increase brake pressure with a dail, and then check with the manual button. Sometimes inbetween brake adjustments I'll have to increase brake strength to make up for wear.
Soundguy
   / Failed Trailer Axle Brakes ... Near Miss! #24
Soundguy; When I offer to haul "for" anyone, it tends to keep freindships and not embarass anyone. I've worked too hard for my stuff to let someone else abuse or neglect it, or even worse, hurt themselves or someone else. /forums/images/graemlins/grin.gif
2016 Ford F550 Flat Bed (A52377)
2016 Ford F550...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
