Fan uner BX24 mid-section
   / Fan uner BX24 mid-section #11
bird1968 said:
Homebrew2, I know how good you are at getting stuff done, so send me a photo of that thing.electic fan..when you get it done! Did you get your BX ready for the snow yet?
Thanks
Richard
Hello Richard, long time no hear from. Hope your business is doing well, I've sent a few folks your way. Keep up the great work.
I hope I never have to mess with the electric fan idea. I've been lucky so far with no skid plate and I'm nearly done with my stick cleanup.
No real snow here in sunny California. I'll probably still be in shorts and sandals at christmas.
Cheers!
   / Fan uner BX24 mid-section #12
I put the skid plate on my 24 a couple of weeks ago as I now have the tractor on 20 acres of somewhat rough terrain. Boy am I glad I did! $600? wow. It was kind of a pain to install on the BX. You will probably need to purchase additional hardware, i.e., longer bolts. The problem is, they don't tell you how much longer you need. I was able to finagle it using the factory bolts, but it was a pain to get on there. If the U bolts they provide were a little longer as well, things would also be easier. The skid plate is a one size fits all with different mounting options for different tractors. That makes sense from a manufacturing standpoint. What I don't understand is writing the installation instructions in the same manner. Each step is filled with caveats for different models; like Step 3: For BX-23 do ...., for BX-24 you may need to do ... or ...
I think they should reorganize the instructions completely so that it reads more clearly. Like, BX -23 owners do these 5 steps, BX-24 owners skip to page 4 and do those 5 steps or something like that. That would be much less confusing.
Other than that, the thing is built extremely well and I'm convinced has already saved me money.
Singlecoil - can you post some additional pictures of the Skid plate - and specifics on how you attached it. Did you have to drill the frame? (where and how many times?) - What sort of hardware, does it use any of the existing hardware already on the tractor? What does the tranny drain-plug look like now - is it covered up or exposed?
I have been thinking about one of these for a while after reading old posts - but I can't get my head around how it really attaches and what it really protects - the picture on eBay only does so much fore me - I'm very touchy feelly...
   / Fan uner BX24 mid-section #14
Cheers!
Rubbing it in, Homebrew2! I guess I would do the same....
BTW for the Skid Plate, here a photo, to help understand the mounting location.
Richard
   / Fan uner BX24 mid-section #15
I ordered a skid plate from Richard today for my BX2230. He said it will probably take a couple of weeks to get here. I will tell you guys why I ordered it.
I have 40 acres. About half of that is woods. The remainder is in yard or horse pasture. The woods is very overgrown and has caused me a few problems, with my tractor, trying to get a handle on it.
The tractor has almost 200 hours on it already. We bought it in March of this year so we do use it a lot. The tractor is currently broken. I ripped a rear axle seal out of it. This is the second time I have done that, both times working in the woods. It costs about $300 to get it fixed.
A couple of weeks ago, I ran a stick up into my HST fan and had to have that fixed. It really didn't look like something I wanted to handle myself. It cost around $100 to have that fixed.
So today, I ordered the skid plate. Might be a little like closing the barn door after the cows are out but anyway....
It doesn't look like the skid plate will do much to protect the axle seals but it can't hurt. I just hope it doesn't make hooking up the PTO shaft for the MMM more difficult.
I really bought the wrong tractor for working back in the woods, but I needed something to mow the yard and the pastures as well as work the woods. I could only afford one tractor so this is what I got. The tractor is fine on the yard or pastures but is really out of its element in the woods. Back there, I need something with more ground clearance. Maybe when we get the SD through college in another year.....
   / Fan uner BX24 mid-section #16
Berniep said:
I haven't seen a bx24 but I think you could cut the driveshaft near one end and take it out then take it to a driveshaft place and have them put a couple of flanges on it so it bolts together. Would be a lot cheaper than 600 bucks.
It also seems like a lot of money just to pull the engine. Does it really take more than a couple of hours shop time? Or are they up to 150 bucks an hour labor now?
Have you seen how that engine is shoehorned in there? It's like pulling an elephant out of a tophat! I'm surprised it isn't MORE expensive.
   / Fan uner BX24 mid-section #17
Quote from Billy: "It doesn't look like the skid plate will do much to protect the axle seals but it can't hurt"
Not to be the village idiot, but how is it that working in the woods can hurt your rear axle seals? I've been trudging in light woods recently myself and have been very careful for my fan (until I install skidplates) and am curious if I should be careful of another woe/foe.
   / Fan uner BX24 mid-section #18
The first time it happened I ran over some bailing wire while working over my burn pile. Wrapped it around the axle and shreaded the seal. This last time, I really have no idea. I was hogging along when I thought I smelled hydraulic fluid. Dismounted to discover fluid absolutely pouring from the same seal as before.
My woods is not "light" though. Some of the stuff I was mowing was well over the height of the tractor.
   / Fan uner BX24 mid-section #19
Oh. That'll do it. Sounds like you're giving the thing a good workout. Just wanted to make sure I wasn't itching for trouble in some of my endevours. Sounds like I'm pretty safe.
   / Fan uner BX24 mid-section #20
So they really did make it harder to work on, huh.
No I haven't taken the time to look at the one at the dealer very close.
UNUSED FUTURE BD43 HYD BACKHOE DIGGER ARM (A54757)
UNUSED FUTURE BD43...
Hyundai HL740-7 Articulated Wheel Loader (A55787)
Hyundai HL740-7...
2007 Saturn Sky Convertible Coupe (A55853)
2007 Saturn Sky...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
Vermeer D16X20A Directional Drill with Mixing System and Trailer (A54865)
Vermeer D16X20A...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
