Farm Pro 2420 starting issue
   / Farm Pro 2420 starting issue #21
What Jacques said. That bendix should jump all the way out to the end of the opening smartly and stay there as long as you crank the starter... Two screws on the front of the solenoid aond remove the jumper tab tot he motor housing and you can retract the solenoid from the chassis. You will see the linkage to the lever that pushes the gear out. There is a slotted screw head between the solenoid and the gear, you can see it in the test video. That is the pivot for the lever... It has an offset bearing surface and a locknut to allow you to fine tune how far the gear engages by rotating that screw...
Ok installed a new starter and it worked. So it was something within my starter. Hopefully someone in future gets some help from this thread. Ill be making a separate thread on how i troubleshot and fixed a fuel issue. Thank you everyone that help me with this.
2015 John Deere 410L 4x4 Extendahoe Backhoe Loader (A55787)
2015 John Deere...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
AGT YRST14 Stand On Dingo (A47477)
AGT YRST14 Stand...
Ford XTRA-VATOR 555D Loader Backhoe (A55787)
Ford XTRA-VATOR...
2008 Chevrolet Impala Sedan (A55758)
2008 Chevrolet...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55302)
Ditch Witch 6510A...
