Farm Pro 2430 not moving
   / Farm Pro 2430 not moving
Fuel line installed and no leaks. While the tractor is running, I can have it in gear but it will not move. My PTO spins when engaged. I use the FEL to prop up the front wheels and engage the 4wd without any movements of the wheels. Hmmm, wondering if I need to check the clutches out to see if they need adjustments?
   / Farm Pro 2430 not moving #12
Even when disengaged, your PTO stub will spin from parasitic forces internal to the drivetrain. Or are you saying it spins with enough torque to - say - run a bush hog? If no, disengage - and apply pressure to the stub with a piece of 2x4. If that's enough to stop the stub from spinning it's normal parasitic force - and your clutchpack could still be bad. But if you can spin a bushhog but not move the tractor in any direction/any gear, that takes troubleshooting in another direction.
//greg//
Greg, I can engage the PTO and it will spin. Disengage it and it stops. I am getting slight movement forward and backwards when in idle speed. Give it some pedal and it does nothing. Braced up the right side FEL and removed the bracket. I now need to know what to check for. I see the pto and clutches but not really sure what to do from this point.
   / Farm Pro 2430 not moving #14
Your looking for a gap. When you step on the clutch, through a series of rods it connects to a fork that sits across the input shaft to the transmission. That fork pushes on a bearing which pushes on three fingers on the center of the clutch, which causes it to release. So you step on the pedal, the fork moves toward the engine, pushing the bearing toward the engine, releasing the clutch. When you are not pushing on the clutch there needs to be a gap between the bearing and the fingers. The gap needs to be 0.1 inch, a tenth of an inch, 2.5 mm.
If you look in the inspection port while pushing on the clutch you should be able to see the fork move and the bearing move and the fingers move.
As the clutch wears, the gap decreases, the clutch needs to be adjusted periodically to restore the gap. If the clutch is allowed to wear all the way until the gap is gone the bearing will push on the fingers even if you don't have your foot on the pedal, and the clutch will be released all the time. This will lead to accelerated wear of the clutch and bearing.
With luck your clutch and bearing still have enough life that adjusting the gap gets everything working again. First step is to verify that this is indeed the problem.
This page has some good pictures to help you get organized:
Jinma Dealer, Wood Chipper , Compact Jinma Tractors
I did see the fork, bearing and fingers move while having the clutch pedal depressed. I will check my gaps when I get home from work tonight.
Thank you!
   / Farm Pro 2430 not moving #16
There should also be a 2mm gap between the two clutches (that's why it's called a clutchpack). That gap should be achieved before you set the throwout bearing gap. But keep in mind that I'm stating this under the assumption that Foton and Jinma use similar clutchpacks. To make sure, can you scan and upload the clutch diagram from your owner manual?
//greg//
I don't have a manual but I can take a photo through the inspection hole, if that will help?
I was able to do some adjustments and now have more movement then I have previously had. I barely press down on the pedal to disengage the clutch. I believe that more adjustment is needed on the clutches.
How does the clutch system work in the Farm Pro 2430? By the looks of the above photo, does it appear that I have no adjustment left?
   / Farm Pro 2430 not moving #20
The 2- double nuts are your PTO clutch adjustments, you need to re-adjust those so that you have 0.30 thousands under the big nut, make sure all 3-are the same, your main clutch adjustment is under the 3-clutch fingers( You will have to grind a wrench down to fit the nut under the finger it will need to be thin),you will need to take the linkage rod off your clutch arm coming out of the bell housing, adjust each one of those 3- fingers so that you have 1/8" clearance from the throw out bearing to the face of the clutch finger, make sure all 3- are the same 1/8". Then reattach your clutch arm adjusting the turnbuckle so that you have 1" of free play that you can push with your fingers.
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A52748)
UNVERFERTH 330 -...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
Miller Welder (A51691)
