DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,629
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Got some pictures to help explain what I was talking about. If they are in the order that I downloaded, the first one should be of the IH 3 pt. conversion. Excuse the dusty tractor, I ground hay for my old mare today, and it is a rather dusty job...
The next two should show the rod from the touch-control, down to the front of the wishbone on the drawbar. In the very center of the wishbone is a loop to the front. This is to pin a swinging drawbar to.
The last picture should be one of the actual swinging drawbar. Came with it, but never used it yet. Would probably come in handy pulling a pull type disk, allowing a shorter turn, and keeping the rear tire out of the disk. I got a Fast-Hitch disk with it, but never used it yet. Not sure that ridgid frame would do near the job my M-F 6 footer will do, with independant floating, manually adjustable gangs. Some day may hook on to it, and see...
Should be able to get a good look close up, as I did not realize the camera was set to the largest picture size it would take... Just click on the image, and it should enlarge...
Hope this helps..!!
Hope this helps..!!
