Farmtrac Front Axle Gear Oil
   / Farmtrac Front Axle Gear Oil #11
My owners manual said to use regular hydraulic oil in my Kubota.
   / Farmtrac Front Axle Gear Oil #12
You are changing what I said, and adding things I never said, to try and make me wrong.
Spin it any way you like.
I'm not adding anything, and I'm not spinning anything, and you were the one who started out with the "corrections" so you can't really point fingers at me for stating facts.
The substance commonly referred to as "gear oil" is different from the substance commonly referred to as "hydraulic transmission fluid" and suggesting otherwise isn't helpful to the OP, or anybody else.
As you said, they have different additive packages, which makes them different. In some applications either can be used. In some applications only one will be suitable. In some situations, substituting "gear oil" for "hydraulic transmission fluid" will lead to thousands of dollars worth of repairs.
I simply told him that some machines use "hydraulic transmission fluid" instead of "gear oil," and that he should check the manual. I find it hard to imagine how anybody could go wrong following that advice.
   / Farmtrac Front Axle Gear Oil #13
UTFs generally provide a level of gear protection described a GL-4. That makes those lubricants containing major additive systems such as HiTECH 8703 and Lubrizol 9990A suitable for use in tractor axle applications.
   / Farmtrac Front Axle Gear Oil #14
I have a Landtrac 390 HST which is the same as the Farmtrac just from the previous company. My manual says the same info as Lineman North Florida quoted. I am also looking to change my front axle lubricant, but the only SAE 90 I can find is $10 - $15 a quart. Not good when I need 10.5 quarts. When I do a search on line for SAE 90 gear oil I keep getting 80W-90. Is this the same thing or close enough not to matter?
   / Farmtrac Front Axle Gear Oil #15
That's all I have ever found is 80w-90.
10.5 qts in an axle? :eek:
   / Farmtrac Front Axle Gear Oil #16
I use Mercury Quicksilver 90w, GL4 gear lube in my Mahindra front axle. Available at Walmart about. $8.00 per qt. While it is designed for outboard lower units, it works perfect and I get a bit of added protection against any water intrusion should that occur.
1605 (A57192)
1605 (A57192)
1999 CATERPILLAR 312B EXCAVATOR (A52709)
1999 CATERPILLAR...
1997 Ford Tandem Dump Truck (A59814)
1997 Ford Tandem...
UNKNOWN  20 FLATBED GOOSENECK (A58214)
UNKNOWN 20...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
