FEL for a Ford BN
   / FEL for a Ford BN #11
Deerlope, Ive seen the Fransgaurd ones I make a few of them here for olks that cant find their dealers. The old Ford one I bought it mechanical hinges the boosters just push the 3 point up past its normal lift height. I ll post a few pics after i resize them.
   / FEL for a Ford BN #12
I grew up on a Nursery with a 8N with a loader. We had it for many years. The bucket was probably about 48 to 60". I remember the tube frame of the loader was the reservoir for the hydraulic fluid so it may have had a second pump. It worked fine as a loader and I loaded many truck loads of loam and peat with it. I'm looking for a 8N for my collection.
Andy
   / FEL for a Ford BN #14
Deerlope Thats the one I copy lol Tyey work good on an older tractor to because you can use an eletric pump.
   / FEL for a Ford BN #15
up to 3 years ago i had a ford 2n ( almost the same as 8n) and it had a fel on it, this fel was kind of unique for this trator as it had a power dump(most had a mechinical dump) this allowed for scraping and a sembelemse of backdragging, although there was no down pressure. was a lot better than some of the older units i had but it sure was heavy and stuck way out. because of the weight and the long distance it stuck out it had a tendency to off load the rear end, especially if u got he front wheels going down hill. i know i have some pics of it . i will find them and post them in a few min. hopes this helps
   / FEL for a Ford BN #16
SORRY I HAD TO FIND THE PICS AND SCAN THEM and resize then for the board , but here they are, gives u an idea of what was/is avalible for that tractor
   / FEL for a Ford BN #17
this is not a great pic. but will give u an idea of what i meant when i said they sitck way out there, sure beat the alternitave /forums/images/graemlins/grin.gif
   / FEL for a Ford BN #18
as u can see they made the superstructure on that fel quite heavy. but it did work and work quite well. sorry i had to get rid of it. was a nice tractor,
   / FEL for a Ford BN #19
Nice pics Frank, I do remember those old FEL's mostly used by small contractors. But I am sure if someone wanted a good all hyd. one that Allied has one that would fit it.
   / FEL for a Ford BN #20
GLAD TO SEE someone else remembers those old things, where abouts in northern ny are u? used to do quite a bit of hunting around the ST. REGIS FALLS AREA.
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2018 Freightliner M2 106 Cab and Chassis Truck (A51692)
2018 Freightliner...
23222 (A50323)
23222 (A50323)
