</font><font color="blue" class="small">( ok I got my new
BX1830. Dealer demo'd removing and installing FEL. It came off pretty good but took 3 people to get it back on. He apologized and said it must not be on level ground. Is it easy for the inexperienced person to install if it is on level ground ? Thanks for any commennts. )</font>
I've had the FEL on my
bx1500 on and off a couple times. I keep the FEL in the garage on a concrete floor. I still need the manual just to keep the steps straight (too much junk in my head to remember, I guess /forums/images/graemlins/crazy.gif)
My floor is solid and level, but it still can be a chore to get the holes for the mounting pins lined up. Last time I needed to "persuade" the right side pin into place with a hammer. I have the same problem sometimes when mounting my Meyers snow plow to my truck, so I'm kind of used to it, I guess. /forums/images/graemlins/wink.gif
I would not want to try to mount the FEL if both the tractor and FEL were not on a SOLID, level surface. I can easily see where settling of a loader that sits outside on ground would be a major PITA. /forums/images/graemlins/blush.gif
My advice to an inexperienced user is to take your time, follow the steps in the manual and and keep the FEL and approach for the tractor on a SOLID surface. Also, be mindful of the hydraulic hoses as you approach the FEL; you don't want to "pinch" them. /forums/images/graemlins/ooo.gif
