UpOnAHill
After weeks of weighing the pros and cons of a tractor, I finally bit the bullet and bought a MF 1529
. But now, I find myself weighing the pros and cons of FEL plow blades vs rear snow blowers---and I need to decide quick!
First of all, my driveway is about 1/4 mile long, is steep (although I'd be going with gravity), curves a couple of times and opens up pretty wide at the top by the garage. The tires are weighted and we will have chains.
A front snow blower is not even an option at this point mostly due to cost, but partly because it seems like a good idea to keep the bucket on the front: is this true? The obvious con to the rear mounted snowblower is having to turn around the entire time, will having a hydrostatic transmission make that any easier? I haven't had a chance yet to look at cost, I'm hoping they are comparable to plow blades.
I've heard that plowing is quicker, but the downfall is the piles of snow that accumulate... which I can deal with. Will plowing with the FEL damage the arms at all? Also, how does weight of the plow factor in? Do I need to consider the lift capacity? (i.e. my lift capacity is 1300 lbs, is a 600 lb plow too heavy?). As far as cost, I think I'll be in the ballpark of $3K.
I would appreciate any input!! Thanks
