Snow Equipment Owning/Operating FEL Snow blade questions
   / FEL Snow blade questions
Thanks
Is that Kwik way capable of adding a hydro angle later if you want?
   / FEL Snow blade questions #12
My 8' blade weighs in at 635 lbs. My TC40D handles it with no problem. If you hit any chunks of ice or heavily packed snow you might tear up the lighter weight plow. I would be afraid of the light weight blade not surviving more than a couple of seasons depending on how you use it.
Kwik-Way Manual Angle Blade 8Ft. Wide, Model# 35-12910 | Snowplows + Blades | Northern Tool + Equipment
yeiks...mine sais it weight 835# also.....
it has the hydraulic angle adjust and a right and a left snow gate. Hardened shoes. Im all ready for the snow.... but really dont want to see it yet. too early
   / FEL Snow blade questions #13
Thanks
They do offer the option. I don't have any remotes on the current tractor, so I don't have a need for it at this time. I am looking at a new tractor for next year that has the third function on the loader, so I will be ordering the kit when/if I pull the trigger on the new machine.
   / FEL Snow blade questions #14
I wouldn't hesitate to put the heavier plow on your NH tractor. The manual angle should work well for you. I have a power angle and seldom have it angled too much either direction. Too much angle will push my front end around. So just adjust your plow for a slight angle left or right and have at her. One advantage of the hydraulic cylinder would be some relief(via the cylinders relief valve) from hitting a solid object.
Thanks for the input guys. I was just about committed to a Worksaver 90" 575 lb that ends up about 2700 delivered. Wolfpack present a less expensive alternative for me. The Kwik way ends up about 1900 delivered. I am normally skeptacle about a Northern product but a blade is a fairly low tech product and Wolfpack speaks well of his. The lead time is about the same on both.
They can both have optional hydro angle added later if desired. The Worksaver has oscillation that helps it stay with the surface but now I have to decide if it is an 800 dollar value. I am kinda thinkin not.
I sure hope I decide what I want before snow arrives. ;)
Any thoughts? I will probably only ever buy 1 front blade and it will be with me as long as I have a need for a snow blade and just do not want to have any regrets. I know - I am a dreamer.
   / FEL Snow blade questions #16
Northern also carries a Kwik-Way with oscillation (float).
Kwik-Way Heavy-Duty Manual Angle Blade with Float 8Ft. Wide, Model# 35-28004 | Snowplows + Blades | Northern Tool + Equipment
You can find out more about the manufacturer at the link below.
DOZER BLADES | KW Manufacturing
They are made for skid steers and pushing dirt / stone. So I figured snow should be easy on it. So far so good.
Beware that the photos in Norther Tool show the optional top extension that they do not offer. They also list a rubber cutting edge that is actually steel.
Thanks Wolfpack. That looks like exactly what I want but at almost 1000 lbs I am afraid that it might be too much for my tractor. From their website I see they might have a lighter one for less than 50 hp tractors. I sent them a note requesting more info.
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
UNUSED RAYTREE REDM32 32" HYD EXCAVATOR MULCHER (A57193)
UNUSED RAYTREE...
Butterfly Artwork (A55758)
Butterfly Artwork...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
UNUSED WOLVERINE TQH-26-01C 3 PT QUICK HITCH (A57193)
UNUSED WOLVERINE...
