Fel stopped working
   / Fel stopped working #1
Jimmy254
Jimna 254
FEL suddenly stopped working. Power steering still works. Fel moves a little when i turn the steering wheel. No previous issues with fel but i have not owned tractor long. There is no strainer in the hydraulic tank with this model. Oill levels are correct. From what i have read on this forum i suspect the steering /divertor valve at fault. I removed it with intention of testing and claening as i thought it would be easier than the fel controller. The trouble is i have no idea how to clean, test or verify if it is working or stuck. Any ideas?
   / Fel stopped working #2
Check disconnect fitting.
   / Fel stopped working #3
Thomas is right, the OEM connectors were a known weak point. However, if that was the culprit it would likely stop the steering from working as well. The usual failure mode is that the internal valves close and dead head the pump, taking out the seal.
Disconnect and re-connect the couplers. Better yet replace both sets with domestic made units.
It is more likely that you have either dirt in the loader valve or the relief valve in the loader control valve has come loose. Take the crown nut off and see if the adjuster has backed all the way out. This is also a common issue with the OEM loader valves and it is an easy fix.
To really troubleshoot the issue you need a hydraulic pressure gauge mounted on a Tee with a set of quick connects to match the tractor. Then you can plug it in to the supply line and check the pressure, then swap it to the return line (back to the priority valve) and check the pressure there.
Priority valves do fail, but not as often as the loader control valve. Also, it is after the loader, so if it failed, it is more likely to stop the steering, it should have no effect on the loader which gets it's pressure directly from the pump.
With no pickup screen in the tank, is there a suction side filter? Some tractors had this feature. If so and it is restricting the flow to the pump, it could result in low pressure. No screen or filter means you are circulating dirt through the system and the loader valve has some pretty tight tolerances and dirt that will pass through the pump will plug the control valve spools.
As far as I know, there are no replacement parts available for the internals of the loader valve. Also there are no diagrams of it either. If you do decide to take it apart, work on a wide clean surface with a rag or towel. Take lots of pics to help put it back together.
Let us know if you have any questions and please keep us posted on your progress. It will help others later.
there is a suction side spin on filter. I dont know the age or condition. Had been planning to change the hyd oil and filter and to learn about the hyd system when this happened so good timing i guess. Havent ever touched the hydraulic system other than check the oil and fiddle with that valve that controls the rate of the 3pt lifter descent. I agree that to analyse this properly i need a pressure gauge T and that the QD's are known issues. If you suspect the PV valve is working I think i will take a picture of the priority valve ports and put it back and focus on the loader control as you suggest. The PV is expensive part and unless someone can explain how it works and what to look for i'll leave it alone. Ill have more questions as i proceed.
ive attached pictures of the priority val e ports. The big port with circlip is the inlet port from the loader control valve. The other single port goes to the rear 3pt lifter. The dual ports go to the steering wheel box. Im only posting the pics on the off chance anyone can see anything wrong when compared to a new valve. I probably wasted my time removing this.
   / Fel stopped working #6
Most equipment the steering would be first valve in circuit and then feed the loader and 3 point so that steering always has priority. Chinese tractor certainly could be different in design.
I should have mentioned that i think my FEL controller is the OEM. I have attached a couple of pics of it. Piper - you mentioned taking a crown nut off and checking if the adjuster has backed all the way off. Can you elaborate on that? I cant see a crown nut and not sure what and where the adjuster is.
The more i think of it the less i understand what on earth that priority valve does and why. I have attached a drawing of what my circuit looks like. There are two ports from the PV going to the steering box. What do they do? One must provide pressure. The other seems tees off to the steering box and the fluid tank.
Some pressure must be getting through to the power steering . Trying to understand how fluid gets past the controller even with no pressure to the curl and lift functions. Are there any simple checks i can do?
   / Fel stopped working #10
I've never understood completely how priority valves work but suspect there is some kind of double relief valve buried in there somehow.
Some Jinma tractors had a separate hydraulic system for steering. Pump, tank, everything.
Some of them had a dual pump where one supplied the hydraulics and one supplied the steering but there was only one pump housing on the tractor.
Some of them have a single pump with the priority valve.
It helps to remember that it was designed as a tractor with power steering, a 3 point lift and some remote ports on the rear. The loader was a total add-on in all cases.
I've never completely understood how the steering box works either but have observed that you can turn the steering wheel round and round, the only stops on the system are at the linkages on the axle. I think the box works by equalizing the pressure on both sides of the steering cylinder. Turn the wheel one way and the system is out of balance so the box sends fluid to one side of the cylinder and dumps fluid from the other side until things are equal again.
Without power steering (older tractors) the hydraulics just were there for the 3 point and remotes. The pressure relief valve for the entire system was in the 3 point control valve. It is set by adding or removing shims under a spring and is basically a pop-off valve. The pump pushes and if the control valve is in neutral the fluid has to go somewhere. It unseats the relief valve and exits back to the tank. Most simple circuit imaginable.
Now add power steering. If it were just tee'd into the circuit AND you were lifting the 3 point while trying to steer the flow would be divided between the two paths back to the tank and the steering would suffer loss of pressure.
As long as you are not turning the steering wheel, there is no need for flow through the steering box so everything just goes to the 3 point normally. Now enter the priority valve. I has to determine if the steering needs pressure and/or flow then decide how to provide it. If the demands of turning and lifting the 3 point (or supplying the remotes) exceeds the needs of the steering the priority valve restricts flow to the rear until the steering is satisfied.
Also remember the remote ports are not like live remotes you might be familiar with on domestic tractors. They only supply pressure out one port when the 3 point cylinder is completely extended and the lever is held in the "raise" position. The other port is strictly a return to tank and can not provide pressure for a dual action cylinder. Topic for another discussion.
The priority valve just gives priority to the steering over the rear end hydraulics. It knows nothing of the FEL.
continued in next post...
   / Fel stopped working #11
Now enter the FEL and it's control valve. There are two spools, one for lift and one for bucket curl. When both spools are in neutral the fluid entering the valve is blocked from the cylinders and must go somewhere. It dumps back to "tank" through the out port. I think this is called an open center system. When either spools is moved in either direction, the tank port is blocked from the incoming port and fluid must pass through the cylinders. The side of the cylinder that is collapsing is open to tank so that the fluid leaving the cylinder has some place to go.
But in this system, there has to be a relief valve so that when a cylinder is at the end of travel the pump does not deadhead. Remember the in port is blocked from the tank port. The relief valve takes care of this by dumping excess pressure back to the out (tank) port. This is the valve that limits the pressure available to the FEL cylinders. It works just like the relief valve in the 3 point controller. Too much pressure lifts the valve off the seat and the excess fluid dumps out the back side. I don't remember if the OEM valve is set by shims or an adjustable screw.
In any case, all fluid from the pump must either go to a cylinder or be dumped back out the "tank" port of the FEL valve. Either by the spool or the relief.
Once it exits the FEL valve it goes back to the tractor and into the priority valve as if the FEL didn't exist. So, as set up by the factory, the FEL can steal pressure/flow from the rest of the tractor, because it is first in line. While lifting the loader the large end of the cylinder is filling while the small (capacity) end is emptying. This means that the loader is consuming more fluid than it is returning and you can short change the steering system for a small amount of time. Once the cylinder motion is stopped by the valve or hits the end and the relief opens, then all flow again is available to the rest of the tractor.
I have occasionally experienced this while lifting and trying to turn at the same time. You will feel the feedback in the steering wheel.
I upgraded my OEM valve with one from Ranch Hand Supply years ago. Best thing I ever did for the loader. The OEM valve is not made very well and it has lots of issues. Looking just now at the manual, it does not show the relief valve. I am pretty sure that I still have the old valve somewhere int he shop. I will try to find it tomorrow and see if I can get some more info for you about the relief valve.
If none of the FEL functions work, it is likely something to do with the relief valve. That is the common denominator.
Since the rest of the tractor hydraulics seems to be working, the pump and tractor relief valve is probalby just fine as well as the suction filter. Although it never hurts to replace a filter, just to be sure.
Until tomorrow...
Thks. Thats gunna take me a while to digest. In the meantime i confirmed flow thru the quick connect from pump to loader. As reputation the QC has indeed failed. I spent an hour trying to separate the male and female ends to no avail so its stuffed but i believe the flow was going through as i could blow air thru it. I think im just guessing now so ill look at replacing those QD's and buying a pressure gauge and tee fitting to see whats going on before and after the controller. Please keep any advice coming as i have a nightmare run with this tractor but i will get there.
good post. Makes sense.
How can i 100% confirm its the controller? Can it be done using a pressure gauge? What readings are to be expected.
could a flush out be worth a try?
Could i borrow the backhoe control to troubleshoot somehow?
Should i remove and try and clean the loader controller. Has anyone done this?
Should i just bite the bullet and buy a new one and just hope.
   / Fel stopped working #14
Sorry for the delayed response. I was able to find the old OEM loader valve but didn't have time to take it apart. Here is a picture of the bottom end.
I think the hex cap is actually the relief valve adjuster. There is a jam nut just under it. The whole assembly is held onto the main body with 4 cap screws. The other two dome shapes are covers for the spool valves.
If it were mine, I would start by backing off the jam nut several turns and then turn the hex cap. Put a mark on it and count the turns. I would try one or two full turns and test. Never having had one apart, I can only imagine that there is a spring inside that holds a pop-off type valve against a seat. adding spring pressure will increase pressure available to the loader cylinders.
If a couple of turns does noting, then I would back the cap all the way off and see what comes out. Do this carefully as it is likely to fly apart under spring pressure. Also lay out the parts in order so that you know how to put it back together.
The first things that come to mind are a broken spring or dirt under the seat of the valve. Next to check would the the valve face and seat are worn and leaking. Spray some brake cleaner or even WD-40 up into the seat to make sure it is clean. Re-assemble and test again.
Since both sets of cylinders are working, it is unlikely that the problem is in the spool valves, but not totally impossible.
You asked about using a pressure gauge. Putting one in the system at either quick connect will only show you the pressure of the system that is controlled by the relief in the 3 point control. To test the pressure to the loader cylinders you would have to tee into the lines that go to the cylinders. Jinma has used different style fittings over the years and you can't tell which one it is until you take them apart. Finding adapters might be pretty difficult.
Remember, the fluid only passes through the open center on it's way back to the tractor unless the loader valve sends it to the loader. The loader relief sets the working pressure for the loader cylinders (up to the limit set by the 3 point relief) and acts as a safety relief for when a cylinder bottoms out,
Thanks for your response. I will try a couple of turns of that hex nut first and then clean it if I have to. I managed to buy a tee and a gauge and fittings so I can test at the rear remote or between the pump to loader valve or between the loader valve to priority valve but not the loader cylinders. If I were to tee in at the Quick connect between loader valve and the priority valve should that pressure reading change when the loader is operated or is pressure always constant as set by the 3point relief valve?
   / Fel stopped working #16
Most likely you will see a drop in pressure as the cylinders move Then return to the previous setting when it bottoms out or the lever is moved back to neutral.
I've never done this test so can't say for sure what it will show.
I put a new hydraulic filter on with new fluid. I tightened the pressure relief valve on the loader controller two turns. I put a tee fitting with a gauge on the line from the pump to the loader controller. I ran the tractor. No change. Gauge was reading around only 200psi. When the steering wheel was turned to the left or right the pressure gauge showed up to about 1000- 1400psi. Holding the pressure at around 1000psi meant I could lift the loader gradually. Could not curl it however. I stopped the tractor. Topped up the fluid. It was low due probably to air pockets which had since gone. Tried it all again. The bucket curl was all the way down. As I was trying to curl it up while moving the steering to and fro it suddenly started working. I backed off the pressure relief two turns. It all tests ok. Looks like pressure is 200psi until either steering or loader is used.
I'm none the wiser what caused the issue but my money is on a dirty relief valve at the loader just as suggested. Thks for your help.
   / Fel stopped working #19
Now you have me scratching my head...
Does it still only show 200 PSI after it started working?
IF it is is plumbed the way I believe it is, then the problem was most likely at the 3 point relief valve, otherwise you should be seeing full pressure at the pump when nothing is moving. Lower of course if the RPM is down, but definitely more than 200 psi.
In any case, as long as it is working properly, the rest is just not all that important. Until it happens again. :)
weird indeed.
I was confused too. I thought the pump was dead but everything is working. My theory is that while the hydraulic fluid is not being diverted to any function (power steering,FEL or 3pt) the pressure is low and the flow is high. Bit like a 1inch water hose seems to have less pressure than a half inch hose but it takes less time to fill a bucket. As soon as a function is used the pressure in the entire system jumps due to the restriction being applied. Where the restriction is applied is like putting your finger over the end of the garden hose to squirt someone. It increases pressure all along the hose but where it comes out is usable pressure. I don't know if the pump increases flow if engine revs increase. I could be wrong of course.
PumpJack Brand Pump Jack (A56438)
PumpJack Brand...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
TANK MANIFOLD (A55745)
2018 Chevy Traverse 3rd Row Seating (A56438)
2018 Chevy...
