FEL, TORO Groundsmaster Put Together
   / FEL, TORO Groundsmaster Put Together #111
Don't understand it...
I asked the seller if it comes with the loader and he acted like he didn't know what I was talking about.
Some people! :LOL:
I guess he hasn't seen this thread:LOL:
Some more pictures with the 4' box blade in the Push mode:
Leveling loose dirt dumped by the V417:
The view from the seat:
   / FEL, TORO Groundsmaster Put Together #114
Got a request from MBTRAC to do a build thread on what is pictured in my Avatar. So here it is.
Started with this 1990 TORO Groundsmaster Traction Unit. It didn't have the rotary deck on it. Notice the seat is offset to the left, the decks are offset to the right to mow around trees like a zero turn.
View attachment 304875View attachment 304876View attachment 304877View attachment 304878
Got it in September, 2004, had just over 3,000 hours on the 3 cylinder, 22 horsepower Mitsubishi diesel engine.
It drives a hydrostatic transmission bolted to a Spicer automobile type axle rated at 1800 pounds.
Here is a better view of the axle (don't ask how I got it :D):
Changed the turf tires to ag type:
View attachment 304880View attachment 304881View attachment 304882
Looks different without the deck. I would kill for a loader put on mine.
   / FEL, TORO Groundsmaster Put Together #116
How has the toro held up for long term use?
I've got a bigger model toro that I'm planning to turn into a mini sky trac.
Planning to put a service truck Crane on it to use as the extending boom
Good, no problems. Have the 4' box blade on it now:
Sounds interesting, please start a thread on the build. I recommend a quick attach on the front. My pin on attachments are difficult to swap out.
A mini sky trac would be like a mini version of my V417: Compact telehandler
   / FEL, TORO Groundsmaster Put Together #118
I too have been scheming how to build an even mini-er telehandler.
Sign me up for that build thread!
Glad this toro loader still exists. Too many cool builds are a ‘flash in the pan’ where it gets 80% usable but then never gets finished and then rots away or gets parted out.
   / FEL, TORO Groundsmaster Put Together #119
Xfaxman,
I noticed your toro w the fel and a few other groundsmasters have the deck lift arms and springs removed. My front blade can't raise much with the arms and spring in place. Is there any trick to removing these? I'd like to remove mine and I know there is probably quite a bit of tension on those springs.
Thanks for any suggestions.
I don't remember any problem removing them, but that was a long time ago.
For those that haven't seen the springs they are visible in this picture:
Found a better view of the arms and springs:
2018 John Deere Z997R (A53317)
2018 John Deere...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
LOT: Air Hose Reels, 220 V Cord, Electrical Cords, Hand Tools, 2-Wheel Hand Truck (A59076)
LOT: Air Hose...
2004 PSI M413XT Motor Grader (A56857)
2004 PSI M413XT...
CAT FORKLIFT (A58216)
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A55852)
2023 Fat Truck...
