FEL Tractor Crane *Proof of Performance*
   / FEL Tractor Crane *Proof of Performance* #11
Good to see things went well. I thought your contraption looked fine for the light load it would be carrying, if it were me I would have contained the pole end in the bucket somehow to prevent it coming back on me should the supporting tooth break due to a cable slipping. It would be very interesting if the actual forces on the turnbuckle and fastening components could be measured which could be easily done if you have one of the value oriented big game dial type scales. There was considerable discussion on the boom, alot of yay and naysayers, and I believe it would prove very educational to find out if the forces on cable clamps and turnbuckles were anywhere near their limits which appeared to be the primary area of concern.
   / FEL Tractor Crane *Proof of Performance* #12
Beautiful!!! When can you come up, and set mine? I'm currently under 'medication' as was suggested by 'wldrbob' in your last 'thread'!!!:licking::laughing::laughing::licking:!
I'd also be interested in your response to jcaron2, re: 'nixing' the winch entirely. I'm sure it had to be an asset for 'fine-tuning the placement....~Scotty
   / FEL Tractor Crane *Proof of Performance* #13
its nice to know the pills havent hurt your sence of humor.glad everything went great.
   / FEL Tractor Crane *Proof of Performance* #14
Good work there, Phil!
I've got the same bucket on my tractor, and I've been working out how to mount a winch to the bucket. It honestly never crossed my mind to mount it *inside* the bucket. I'll have to look at that option again.
Once again, good work, good documentation.
   / FEL Tractor Crane *Proof of Performance* #15
My favorite part of the whole story:
The RF control on the winch, however, failed to respond while working the 2nd truss. (Harbor freight - go figure.)
Amusing, and oh-so-true.
   / FEL Tractor Crane *Proof of Performance* #16
Maybe be useful to hoist up the plywood or metal roofing also?
   / FEL Tractor Crane *Proof of Performance* #17
Whats the final $$$ and time total you have in the construction of the crane? And how long did it take to put up all the trusses using the crane?
   / FEL Tractor Crane *Proof of Performance* #18
I am glad you are allright!!:thumbsup:
   / FEL Tractor Crane *Proof of Performance* #19
Tell you that there crane looks like you married up one of them boomer rigs they had on the docks down in New York City with a loader tractor except them boomer trucks had a pully thing built right into the end of the boom. I seen outfits like that when I was working for the railroad, big tractors with them tracks on em with a boom hanging off to one side, and they could pick up one end of a boxcar with them.
Thing is I can't understand why you went to all that trouble. Fellow here builds all sorts of barns and has himself a piece of aluminum pipe with a pully thing on one end and about a 5 foot piece of pipe on the other end that sits kind of like a capitol T but upside down so the T part is on the ground. It sort of looks like clothes drying posts except the part the laundry lines hang on is sitting on the ground and the part that's in the ground is sticking up. Back when he had a lot of work and help he'd use a block & tackle on that post, but since things slowed down its just him and his boy, so they went over to Harbor Freight and bought a winch, and now the winch does the lifting. That Harbor Freight is quite a place I tell you, seems like they have more stuff in there than Sears used to have in their farm store before Sears closed the stores.
Now this fellow has a 2 wheel cart with a pair of wheels like them fancy garden carts that got wheels that look like a bicycle wheel, and he and the boy just lift the truss one at a time and clamp the wheels onto the truss at the pointy end and push that sucker right into the barn. They got considerable practice and can position the end of the truss slicker than you ever seen. The pointy end is still down at the ground, and one of the eave ends is sitting on the wall.
Then they hook the winch cable to the pointy end of the truss and hit the switch. They got this plastic box with a battery in it for the winch and a cable from the box to the winch. Tell you what, in less time than it takes to write this all out that piece of pipe with the winch flips the pointed end of the truss up where it belongs and the other fellow is on the ladder over by the end that ain't sitting on the wall. and ready to go. When the end that aint on the wall gets just to the right height he gives a little push and then pulls and the other fellow who is running the electric winch powered by the battery in the box flips the switch the other way and the dang truss sits right in place on top of the walls. Then the fellow who runs the winch gets on his ladder and puts nails in the end of the truss that was sitting on the wall, and they both climb down and take that cart of theirs over to where the trusses are piled up and get another truss.
He was telling me his first idea was to just use a boat winch but for just a few dollars more he got the electric one and he ain't near as tired when he finishes for the day and gets home.
Another thing this fellow swears by is wind straps on them trusses. They take some of that steel strapping like you use on pallets and about 4 1 1/2 roofing nails and strap the end of the truss right to the top beam the truss is sitting on. He says this makes the connection a lot stornger and he never yet had one flop over like some do. It makes sense.
   / FEL Tractor Crane *Proof of Performance* #20
Great job. Sorry to hear about the winch, mine is the older style, wired control. I found using the winch to be very helpful when setting my roof panels.
Really enjoyed all the pics.
David
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
Sakai SW354 (A60462)
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
Cub Cadet Challenger 550 UTV (A59814)
Cub Cadet...
Erskine Skidsteer Dozer Blade (A59814)
Erskine Skidsteer...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
