jaydee325
Veteran Member
- Joined
 - May 21, 2013
- Messages
 - 1,205
- Location
 - Casco, Mi
- Tractor
 - John Deere X584 Garden Tractor & LS R3039H
Daves1708
I checked and this is what I found. The battery has 12.2 volts in it. When I put the red lead on the starter connection and ground the black lead it read 12.2 volts. When the key is turned (for starting), it reads 11.9 volts. This seems strange! What do you think?
Stu
12.2 volts is only 60% charged.
Before you can trouble shoot, you need a known good fully charged battery. Put it on a charger and charge it until it is at 12.6 volts rested (i.e. no post charge surface charge.) Then get the battery load tested. Yes I know you said it was a new battery, but I've seen defective new batteries. Then make sure all connections at the battery and down stream are clean. This means disconnect at starter, frame or block grounds and inspect and clean. I've seen connections that look good, but when opened up, they were bad.
Since you said it was stored in the barn for 30 days, I'd do a visual on the entire wire harness to ensure the critters have not chewed up some of the wiring.
