Fence Posts in concrete or not?
   / Fence Posts in concrete or not? #1
HighLoader
Aguanga, CA
New Holland TC40DA, Kubota K008-3 excavator
I have started fencing our 5 acre and 20 acre property, the perimiter and interior. I am using 2,7/8s steel oil well tubing for the posts. I have been drilling 2 foot holes and then setting them in concrete. Yesterday I tried setting a couple without concrete. I used a steel rod to pack the dirt in around the post. I was suprised how secure it was. Without the concrete, will the posts loosen and lean over? Without the concrete to protect the post how long will the post last? Can I coat the post with something before I put it in the ground? My hope is that I can get a good 40 years or more out of these posts so when I am in my eighties I will not have to do this all over again! Anybody out there with some advice? Thanks:)
Here are some of the posts I have set so far.
   / Fence Posts in concrete or not? #3
Sorry to digress but that is a lovely picture.:D
Concrete will definetly help hold the posts more securely. As for not using concrete this may work just as well but may depend on the type of soil / weather conditions and how far they are buried.
As for the posts longevity it again depends on weater/type of soil/pipe metal composition and schedule.
   / Fence Posts in concrete or not? #4
I have never set steel pipe posts, but I always go down at least 3-4'. I think that's from my time in MI trying to avoid frost heaving. But I only set corners in concrete anymore because we seem to change fences around now and again. It's easier to pull out and move w/o the concrete, and SC clay hardens quite a bit. I imagine it really depends on your local soil conditions.
-Brian
   / Fence Posts in concrete or not? #5
Setting every post in concrete is overkill. As stated by others, soil and weather conditions will determine if your posts stay vertical. I would set every fifth post in concrete. I don't use steel but this approach has worked for me using cedar posts. All the posts do is hold your wire up off of the ground.
Nice looking picture.:)
   / Fence Posts in concrete or not? #6
I would say yes to the concrete since you are only going 2' deep. You don't have to mix the concrete, dig the hole, stick the pole in, pour in some water, pour in concrete mix, more water, move down the line. Worked great for me!!
That picture is beautifu, looks like you have alot of fencing to do, good luck.
   / Fence Posts in concrete or not? #7
Growing up on the dairy, My father taught me a general rule. Wood in dirt, steel in concrete.
BUT, like the other guys said, it probably depends a lot on the soil conditions of the area.
That pic is so beautiful, I don't believe I'd plant another post on that ground!
   / Fence Posts in concrete or not? #8
WeldingIsFun,
Are these Eastern Red cedar?
How long have they been in the ground and how are they holding up?
I have lots of Eastern Red Cedar. I see some of it used for fences. Some look ok while others are falling down. I don't know how long the posts have been in use though.
I think if I just used the trees taken down by ice storms I could fence in my land with them.
Later,
Dan
   / Fence Posts in concrete or not? #9
Growing up, we always used wood post and never set them in concrete. We did, however, tamp them in using heavy tamping bars that weighed around 15 to 20lb. This was in rocky soil and we used softball size rocks mixed with dirt for the tamping. This is cheaper but a lot more work than mixing up two bags of ready mix. A lot of folks don't tamp a post properly because it's hard work.
Now days, we use steel pipe post and set them in concrete around 3' deep and we use two 80lb bags of ready mix. We tried driving them and here's what we found: If the soil is rocky and non-expansive, it works pretty well. If the soil is expansive (meaning it shrinks when dry and expands when wet), the post will be tight in the winter and loose in the summer.
In general, if you drive post or tamp them in, the soil needs to be rocky and/or the post need to be set deeper.
We also only use a line post every 50 to 100 feet and t-post in-between on 10' spacings. This for barb wire and barb/netting combination fences. 7 1/2 foot t-post if the soil is tight and longer if we are in sandy soil. For rocky soil, we sometimes have to pre-drill with a 40lb air-rock drill.
   / Fence Posts in concrete or not? #10
dmccarty said:
WeldingIsFun,
Later,
Dan
Dan, they are Ashe Juniper Cedars in this area. There are some cedar fence posts on my property that have been here nearly 75 years and they are like iron. You cannot drive a wire staple into them. I have put in some cedar posts that have rotted out in four years. Then I have others that are still as strong as the day I set them. I fenced my entire place with posts cut from the prpoerty. What I have found is that if there is a dark red heart, it will last. No heart, chip it or burn it. I always learn by the mistakes I make.
:) Thanks for all the replys! In northern Nevada it can get cold and frost could be and issue. The other property in southern California I don't think it is a problem. Both areas don't get alot of rain, so maybe they will not rust out for awhile. I could use that metal rust primer or coat them with black top. It is a lot of work to pack the dirt around a post. Maybe I could use a 4 inch auger instead of a 6? I am going to do some more testing.
   / Fence Posts in concrete or not? #12
I agree with weldingisfun concrete every fifth post.
Do you expect a lot of big cracks in the soil?
Around here the late Summer cracks can swallow a fance post whole. Thats why I would concrete every 5th post.
It would be good if you can find a way to drive the posts in.
A driven post is 1.7 times as strong as a tamped post.
I understand those post drivers are fast. With that kind of pounding doesn't the top of the post get smashed or mushroom? I am putting nice metal caps on the top of ever post to keep the rain out and give it a finished look.Everyone is going to laugh at me....believe it or not I have been useing a one person "earthquake" gas auger I bought at Lowes for $225 and a 6 inch auger bit for another $100 bucks. I was useing a Gearmore PTO Auger on my other little New Holland TC24da and it was hard to position and would get tippy on some of the slopes. The down preasure was not good either. I did about 30 or 40 holes with it and then tried this little hand held auger and swithch over. I will drill five or more at a time so I don't have to keep pull staring it...even though it starts pretty easy. I use a string line with stakes and it is much easyer and faster to position each hole along the line with the hand held auger than it was with the one on the tractor. I will admitt it is more exercise. Also, if I hit a root or rock bigger than my fist and am day dream'n I could hurt a wrist....I did sprain my wrist one time that way and have been careful ever since. I have thought about getting a hydrolic Auger or a post driver but have got pretty good at doing it this way. So I have a $26,000 tractor and a $16,000 excavator and using a cheap $225 post hole digger!!!:)
Brian
   / Fence Posts in concrete or not? #14
Only 1.7? All this time I thought it was 1.75 times stronger. Can't believe I've been doing all that tamping for just 1.7. Darn!!:mad:
Just funnin' with ya'.;)
   / Fence Posts in concrete or not? #15
Brian
My wife and I used one of those Earthquake augers to put in 1.5 miles of posts, Now we have a tractor and PHD. Still have the Earthquake, just in case I need to sink a hole somewhere that tractor can't go.
Around this part of the country we stuff newspaper down the top of the pipe/post about two or three inches (depends upon the length of your fingers) and then set a ball of wet concrete mix (Quikrete) on top of it. Use enough concrete mix and you get that nice finished rounded top you want. It is a whole lot cheaper than those metal caps. Think about it.
   / Fence Posts in concrete or not? #16
I install iron fences. We use concrete. A oldtimer showed me the best way to do the concrete. You pour about a coffee can of water in the bottom of hole. Then set in pole pour in part of you concrete, tamp it down like you did the dirt. Then pour in more concrete untill the hole is full. The pole will then be set. If your ground is real real dry pour some water in ground around outside of hole. The moisture will get to the concrete through the ground. The next day concrete will be set. Because of the slow setting of concrete it will no shrink back from pipe. When it shrinks back from pipe it will leave a pocket for water to stand and rust sooner. big dan
   / Fence Posts in concrete or not? #17
If you ever do get a freeze down below 2 feet...they'll pop out of the ground. Thats not deep enough. It also DOESNT ALLOW enough "contact surface" ( i.e. "footprint) with the surrounding soil.
I took a course once on constructing "Timber frame homes"...and this is what they taught. They said that 20% of the "sticking out length" was suppose to be IN the ground with a MIN of 30" and ALWAYS below any frost line. Also the deal on concrete around a post was this.
Bore the hole..and on the bottom of the post insert a "pin" that goes THRU the post and sticks out about 4" min on both sides ( with a metal post you could weld a piece of rebar across the bottom to do the same thing) Put the post in the hole and pour enough concrete in to cover the "pin" by about 4 inches of concrete...plumb the post and brace it and let the concrete harden up. What you wind up with is a post with a BIG WASHER attached to the bottom of it. Fill the hole with TAMPED soil and make sure its tamped well.
   / Fence Posts in concrete or not? #18
Fencing that much I'd also consider a post pounder. They have a cap that goes over the top of the pipe and the weight actually hits the cap, not the pipe directly to prevent mushrooming. All commercial fence companies that install chain link fence with metal posts ( which is close to what you're doing with the oil pipe) use a pounder. It's quicker, tighter, and you can plumb as you go. (The pounders articulate in all 4 directions so you drive at any angle you want). There's also no backfilling, tamping etc. When you're done pounding you're done. I bet you can do a pole every 5 minutes with a pounder! BYW - I echo the other sentiments about your land - beautiful!
   / Fence Posts in concrete or not? #19
My farmer friend has one of those and I got to watch him use it this past fall. I have to agree 100% with ya. The "proper length" piece of pipe...driven down with one of those makes concrete around the post a waste of $$ and effort.
   / Fence Posts in concrete or not? #20
Under what conditions do people ordinarily set T-posts in concrete? Why would pipe posts be less sturdy without concrete than T=posts without concrete?
If the pipes are set deeply enough then once the dirt settles in around the pipe posts thay will be as or more secure than T-posts if you set then as or more deeply. Tamping the dirt will firm them up without a wait for them to naturally settle. Concrete is more important on high stress applications such as stretch fixtures (H braces and the like), corner posts, posts with gates attached, areas where stock is handled and may take a run at the fence, and similar applications.
I'm not saying concrete might not make your posts more secure but that typical barbed wire fences with T-posts don't use concrete on the T-posts and you shouldn't need it either unless you have special circumstaces.
If you are not using barbed wire and are fencing buffalo or separating bulls, or similar applications where the side loads will be considerably more that a typical barbed wire cattle fence, then concrete is a cost effective consideratioin as are side braces and or all welded pipe fence or with cable or sucker rod horizontals.
I admire the fences at the Wichita Mountains Wildlife Refuge near Lawton, Oklahoma where herds of buffalo, elk, etc. are fenced in. Not T-posts and barbed wire!
Pat
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
2001 INTERNATIONAL 4900 WATER TRUCK (A58214)
2001 INTERNATIONAL...
2017 John Deere 5090GN (A53317)
2017 John Deere...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2015 CATERPILLAR 140M3 MOTOR GRADER (A58214)
2015 CATERPILLAR...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
