Fence Posts - need advice where to buy
   / Fence Posts - need advice where to buy #11
I'm putting in about 2000' of the Ramm 5" flex using 4-5x8 line posts and 6-7x8 corners. Got posts from TSC, they are yellow pine, CCA .40. The 4x8's were $7 something and the 6x8's were $15. Ramm has a sale on this month, they were cheaper on flex than anybody else. TSC gave me 5% off for buying posts in bundles. Centaur also has flex fence and might be closer to you than Ramm for shipping. 11 rolls of 5" flex and h/w was 1800# on the ticket but when I unloaded it I don't think it weighed but about 1/2 that.
CCA treatment is only available now for farm/industrial so you want to look in farm stores. Rural King had the same posts, made by Green River post company in Sebree, KY. I would think you could find CCA yellow pine posts pretty easy in TX.
Landscape timbers end up rotten and full of termites around here.
Having said all that, I see mostly hot wire on T-posts or just regular welded wire, barb wire, around here.
   / Fence Posts - need advice where to buy #12
I'd like to know what kind of post you're getting for $3.50? I can't get anything that cheap. Heck, I pay $6 for a treated 2"x4"x8', much less a fence post. Even 4" peeler cores cost more than $3.50.
Same here!! 4x4x8' treated pine posts at my Home Depot are $5.97 (and sometimes $6.97 :() ... If I saw some for $3.50 I'd start dancing right there. But only for a moment, then quickly buy them all.
   / Fence Posts - need advice where to buy #13
I used 6" by 8' treated wood FENCE posts about 16 years ago and am doing great. I would rather spend extra now than have to redo later. I have heard you don't even THINK about using landscape timbers for fencing up here.
   / Fence Posts - need advice where to buy #14
For the OP, why not upgrade the posts you want to use (ie, get better ones) and build the fence in stages, as the money becomes available. That's how I do my projects.
   / Fence Posts - need advice where to buy #15
Greetings -
this spring we will be doing some serious fencing. I need about 3000 ft of horse fence to get all my pastures done. The front of the property has the nice vinyl fence but I am not doing this in the back.
I am looking for suggestions that are more cost effective.
I am thinking about the standard treated fence posts and then run the slick wire on two lines (middle & bottom). At the top I am thinking about the RAMM FLEX. This will give the horses the visual aid to identify the fence.
Right now my concern are the fence posts. 375 posts at $3.50 a post at the local Lowes/Home Depot is killing me already.
Any suggestion where I can get this cheaper in the Greater Houston Area?
Check out this: Stay Tuff Fence Mfg Inc. - High Tensile Woven Wire Fence and Fence Installation Tools
Also go to mccoys and talk to somebody about getting a bid on the materials you need.
Lumber and Building Supplies | McCoy's Building Supply
   / Fence Posts - need advice where to buy #16
I put in high tension fence 2 years ago. Spaced the wood posts 100', used steel Tposts in between to maintain wire spacing and follow ground contour. Some Tposts are 25' apart, some are closer depending on terrain. I used 6" round tapered treated posts from Tractor Supply, 8' long, 5' above ground for the line. End and corner post assemblies are 10' and driven deeper, lots of force pulling on that wire. I used a post pounder to put them in, only takes about 30 seconds to pound a post. I used 6 wires, alternating hot and ground so even if earth ground doesn't work, horse still feels a jingle when they touch 2 wires.
   / Fence Posts - need advice where to buy #17
You can add me to those who would not use those landscape timbers. I've used them for a number of things, including fence posts. They're great, if you intend to rebuild the fence in a year or two.:laughing: I'll never use one again except for indoor jobs where they never get wet. Incidentally, I also tried building a fence by drilling the post holes, set the posts and filled in around the posts with pea gravel which I'd heard worked well. But it didn't work well at all in my "Wilson Clay Loam"; i.e., black clay. When it got dry and the soil cracked, all the pea gravel sank out of sight into the bowels of the earth and I had to fill in around all those loose posts with dirt.
   / Fence Posts - need advice where to buy #18
I'd use 2 7/8" drill stem pipe for the corner braces and "T" post for the line post. Both are easy to find here in Texas.
I would also use railroad ties or cut down telephone poles before I used the post you had the link for. A good fence isn't cheap, but should last you years.
Like mentioned, there isn't anything much worse than having to re-work a fence.
   / Fence Posts - need advice where to buy #19
Find someone in your area that sells cedar posts. Those landscape timbers will not last long. Cedar will last longer than any treated posts in our climate.
Cedar or Larch.
wrooster
   / Fence Posts - need advice where to buy #20
Two best tools I bought when putting in our fence was a driver to pound the posts and a palm nailer. We put flex fence around the back and the palm nailer made quick work on the fasteners. The post driver was a great to until I hit the rocky area. I used Pt 4x4 for the runs and the 6" round posts from TSC. The corners I did cement in. It has all been standing for the past three years, only time will tell how long it will last.
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2018 Caterpillar...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A56138)
2010 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
40 CONTAINER W/CONTENTS (A55745)
40 CONTAINER...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
378813 (A51573)
378813 (A51573)
