KYDan
Platinum Member
I am planning replacing about 1,500' of field fence this winter and early spring and I thought I would share some things that interested me regarding field fence. I am using RedTop 48", 9 gauge top & bottom wires, 11 gauge stays, 6" square. The last fence I used was Baekert and it was/is worthless. After 7 years it has mostly rusted away and the deer walk through it like it wasn't there! I set 6" treated line post 16' apart with heavy metal studded T posts at 8' between the wooden posts. The corners were/are 10" treated posts. The posts are still fine. When I was installing this fence 7 years ago I broke my faithful, ancient fencing pliers and lost my linesman pliers as well. I bought a pair of each at Harbor Freight a couple of years ago and I became angry everytime that I attempted to use them. Neither pair will cut 9 gauge wire and the linesmen's pliers won't even cut 11 gauge! Plus they won't open easily even after extended use. I started clearing out the old fence line preparing it for the new fence and I used the old HF pliers today. Junk! I started looking online for some good fence and linesmen pliers. I was going with Irwin until I saw they were made in China. No thanks. I called my local Do It Best Hardware and they have the Irwin and their housebrand pliers, both made in China. However, they also have 9 1/2" Channel Lock linesmen's pliers in stock. I went to check them out as well as the Irwin and their housebrand. Their housebrand were identical to the POC (piece O' Cra_) ones that I have. The Irwins were marginally better. The Channel Lock linesmen's pliers were excellent and I bought them ($30). I just orded a set of the Channel Lock fencing pliers from Amazon.com and I expect them to be as good as the linesmen's pliers. They were marginally cheaper than the linesmen's that I bought retail. BTW, Channel Lock Tools are still made in the US, Pennsylvania! End of rant.
