Fiber cement siding
   / Fiber cement siding #21
P.S. forgot to mention paint. I won't install anything that requires paint. That includes all outside surfaces, trim, etc. :)
   / Fiber cement siding #22
More pics of the back of my house-
1st- what it looked like when I bought it
2nd- with new windows, siding and paint
3rd- with new roof
   / Fiber cement siding #23
Smart Siding is OSB with a glazed finish to look like wood grain. I like it for painted porch ceilings, but that's about it. It's better then bare plywood like T1-11, but nowhere close to Hardie.
   / Fiber cement siding #24
That settles it Eddie. Thanks for your advice. :)
What do you think of Polymer?
   / Fiber cement siding #25
We're putting Hardie on our house now. Plain sheets under the deck and beadboard sheets on the wrap around porch ceiling. Planks on the siding. We had some sort of cheap pressed together sawdust siding that started coming apart where it got wet, and raw plywood where we're putting sheets. The Hardie's fire resistance is a big plus.
   / Fiber cement siding #26
I put it on my cabin for a couple of reasons...fire and bugs. It has held up really well. Keep in mind this cabin can see snow loads up to 15 feet high. I would not see any reason to not use it, just understand how to instal it and it should see lots of years of use...
   / Fiber cement siding #27
Put Hardi siding on the ends of a shed I built 12ish years ago. It should have painted it but it had a primer on it and it is/was a temporary shed. :rolleyes: The Hardi does get wet and it has been just ok. I suspect it can dry out since both sides of the material are not enclosed. I would use it again since it has worked good so far. :laughing::laughing::laughing:
Later,
Dan
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A55787)
2025 68in Dual...
2004 Ford F-550 Mason Dump Truck (A55788)
2004 Ford F-550...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
