RedNeckRacin
Elite Member
- Joined
- Jan 6, 2008
- Messages
- 2,506
- Location
- Western PA
- Tractor
- John Deere 5083E MFWD, Kubota L3400 HST
I've had the rail system and used it to pull a GN horse/stock trailer. I thought it worked well. The only 'issues' I had were as follows. Nothing major, but if I were to get another GN hitch, I'd probably opt for the underbed type.
1. I had a plastic bedliner that was cut out around the rails. The bedliner was about the same height as the rails, so I could slide things in the bed easily. However, the holes the GN hitch fit into filled with debris that held water, had to be cleaned out to both use the hitch and prevent rust.
2. The GN hitch used four pins to attach to the rails. The pins also had 'clips' that I had to put in holes in the clips. Not fun when the rails were packed with debris or frozen.
I didn't mean to say it wouldn't pull a trailer or anything like that. I just felt like it pulled differently than even my truck which had the ball mounted under the bed. When he changed out the beds and mounted it under the body, I bet it dropped the ball height almost 8". Sure doesn't sound like much, but it took a lot of the front end bounce out of the truck.
If a 5'er is the goal, I'd cruise over to the rv forum and see what those guys recommend. I imagine its B&W though.
