Actually, emissions are improved in the simplest, easiest to understand way possible. Any job requires a fixed amount of work to complete. The power gain from the turbo allows the same size engine to complete more work in less time and using less fuel. The less time spent burning diesel fuel, the lower the emissions. The amount of emissions produced is directly proportional to the amount of fuel used. Engine X may take 13 hours to plow a field, burning 10 gal of diesel while engine T might do it in 10 hours, burning 8 gallons. The ground speed might be the same, but the 65 hp would handle one more plow bottom, giving it a wider cut. Total emissions produced doing the job therefore would be about 20% less with engine T, as would the fuel bill, plus the "extra" time could certainly be well spent on most farms. Depending on fuel usage, this pretty much makes this a "no-brainer" when it comes to larger tractors doing "real" work. If fuel was still under $1.00/gal, turbos would not be so popular today.
